Page 306 of 371 FirstFirst ... 206256296302303304305306307308309310316356 ... LastLast
Results 3,051 to 3,060 of 3706
    May 2012
    #3051
    Sir helbanes buti sayo may maingay lang namin,nanginginig pa parang tataon ung makina.may isang maganda sa avanza compare sa kuya nya yung air con system sa likod,mas malamig yung avanza kesa innova lalo na pag noontime at galit na galit si haring araw.
    Posted via Tsikot Mobile App
    Aug 2014
    #3052
    ganyan dn naging problema ng 2007 Avanza G ko. pinasok ko s casa (Toyota Alabang) last Jan. 2014
    May 2012
    #3053
    Anong sabi lip-cher032302? Normal ata na sa avanza yung ganon during highway speeding.
    #3054
    Quote Originally Posted by jyg1995 View Post
    Maybe you need to have your unit checked. Elevated engine noise is normal during highspeed but not to the point it is disturbing. Sound proofing has improved in later versions. Nanginginig during highspeed is not normal.
    The tires on a bad road produces more noise than that of the engine. You will notice that on good grade A asphalt.
    Drive safely!
  5. #3055
    Mga Sir, saan po kaya makakabili ng aircon vent ng gitnang aircon sa taas nakalagay. all the 3 vents are all destroyed and how much po kaya ito? TIA
    Ask ko na din kung may FB site ba tayong mga Avanza Owners?
    Sep 2005
    #3056
    https://www.facebook.com/groups/avanzaclub.ph/
    Quote Originally Posted by archangel_1911 View Post
    Sep 2014
    #3057
    Gud pm po planning ko po kumuha ng avanza 1.3 E M/T ask ko lang po kong kaya po ba umakyat ng Baguio with 7 person inside. Thanks
    #3058
    No doubt na kayang kaya ng 1.3 engine. It may be slow pero di dapat mag-alala.
    Proper gearing is a must. On uphill never let your RPM get below 2000.
    I would advise to get your tire pressure a bit higher than usual. Also use a higher octane gasoline upon your travel uphill.
    This should help.
    Quote Originally Posted by Bagitongdriver View Post
    Sep 2014
    #3059
    Need some help pls. My 2007 Avanza 1.5 M/T (35K odo) is giving grinding noise when you reverse (almost full turn). Wala naman when reversing straight. What could it be? Is it dangerous to drive the vehicle?
    First time car owner here! TIA
    Jul 2014
    #3060
    Quote Originally Posted by helbanes View Post
    honest opinion mag-Innova nalang po kayo. Underpowered ang makina ng avanza kaya kung marami kayong sasakay sobrang lakas na niya sa gasolina. 1.5 AT ang unit ko at madalas ako lang mag-isa ang nakasakay, more or less P1500 ang gastos ko kada linggo nasa 200KM ang naitatakbo ko. Mas sulit ang innova pag maraming pasahero, at mas maluwag ito kumpara sa avanza
    Try nyo suzuki ertiga panalo kayo mas mura sa innova pero mas comfortable ka at pra ka lang ngdridrive ng honda jazz...7 seater
Toyota Avanza Owners & Discussions [continued]
