Page 680 of 749 FirstFirst ... 580630670676677678679680681682683684690730 ... LastLast
Results 13,581 to 13,600 of 14970
    Jan 2010
    #13581
    Good Day!
    can somebody help me? i dont know what to do... bigla na lang namatay yung radio ng 1.5 avanza namin. I don't know if fuse lang sya or what... can somebody send me kung saan ang location ng fuse nya? nabasa kasi yung manual ng avanza nung bagyong "Ondoy" and i've been trying to find a copy of the manual sa internet kaso wala.
    any suggestions din kung anong dapat gawin sa kanya..
    thanks a lot!
    May 2007
    #13582
    Any of you guys have an idea how much ang pms (30,000)km sa toyota? Tsaka ano usually kasama sa 30,000km check up?
    Thanks.
    Aug 2005
    #13583
    Quote Originally Posted by stoicjeng View Post
    Good Day!
    thanks a lot!
    I do not have the manual with me. I can check tonight unless some one gets to answer your query.
    But there is a main fuse and a smaller fuse after the Acc switch of the ignition. The main may be located at the engine bay. the smaller fuse may be below the steering wheel left side.
    Aug 2005
    #13584
    Quote Originally Posted by hops View Post
    Thanks.
    same lang sa 10K pms. assuming you follow the schedule.
    Jan 2010
    #13585
    can you give me an idea kung san dun yung fuse ng radio? nasa main ba sya or yung nasa ilalim ng steering wheel?
    thanks a lot!
    #13586
    Timing chain ang gamit. Iyong older models ng Avanza J, hindi nakakabasa ng MP3. Music CD lang.
    Also the 2009 J model sir,
    Eto gamit ko FM Modulator, bought from cdrking, 480 lang, same products na benta sa mga car accessories shop na almost 1k.
    Gamit dito ang USB flash drive and SD Card with MP3
    Good Day!
    thanks a lot!
    Near to clutch pedal, may fuse box dyan, hanapin mo ang fuse na ACC 7.5A
    Yong fuse na color red(7.5A) nasa upper right next sa color blue(15A)
    Wala sa Manual ang location ng mga Fuse.
    Aug 2005
    #13587
    thanks a lot!
    Quote Originally Posted by xda2jojo View Post
    Yup nasa kick panel sa ilalim ng steering wheel. left side. tama si xda2jojo. 7.5 Ampere fuse labeled as ACC. nasa upper right, pangalawa. katabi ng 15 Amp fuse para sa CIG.
    mayroon akong electronic copy ng manual.
    Jan 2010
    #13588
    thanks! cge check ko na lang...sana nga fuse lang ang problem...wag naman sana yung radio...update ko kayo if ok sya.
    thanks a lot xda2jojo and meledson
    Dec 2007
    #13589
    Good Day!
    thanks a lot!
    Suggestion ko, try resetting the HU muna, poke the reset button with a pen tip or a paper clip, and see if it wakes up. You'll have to set it up all over again, though. The reset button is recessed, next to the 6th memory button (lower right corner).
    That's what I do when my Kenwood DPX-MP2090 goes into a coma. Unfortunately, it happens sooooo often that I've resigned myself into accepting the chore of resetting it almost 3 times a week. :cry:
    Sometimes nahuhuli ko siya (parang may Christmas lights ang display niya), I just push firmly but very fleetingly either the area of the MENU button, or the volume control button/dial. Minsan I have to push the whole unit to the left and/or right para lang mag-behave siya. Haaay naku.
    HTH.
    [SIZE=1]3652
    [/SIZE]
    Nov 2006
    #13590
    Sir Pres, kung pwede, pa email naman ng manual sa dfcs*dfcsantos.com. Na-Ondoy din ang manual ko. Thank you!
    Dec 2007
    #13591
    Quote Originally Posted by dfcsantos View Post
    Pa-email din po niyan, Mr. President! You know my YM email.
    Better yet (if I may suggest) send it through http://www.yousendit.com or some similar file sending site and just post the link here, para mas marami ang pwedeng mag-download.
    Either way, TIA!
    [size=1]3653[/size]
    Apr 2008
    #13592
    salamat sir mel, mykelA75 and xda2jojo sa replies!
    magandang idea nga yung FM modulator dati nakikita ko lang sya sa cd-r king pero diko alam ang gamit, otherwise palit na lang ng head unit pag may budget pa
    #13593
    alam ko libre repair sa Seatmate.. dalhin mo lang resibo.. yung sa akin papa repair ko din.. di ko pa lang ma tyempuhan kung kailan ko ibabalik..
    kay Boy C.. mas maganda yung ilalim nya.. naka velcro tape ba yun.. mas malinis tingnan..
    ok, tawagan ko muna ang seatmate para maschedule ung repair...
    nasa Casa kasi si vanC for Repair at 25K PMS
    at tanong ko rin kung pwedeng ipa velcro tape...salamat sa reply...
    Sep 2008
    #13594
    Quote Originally Posted by woohoo View Post
    Either way, TIA!
    [SIZE=1]3653[/SIZE]
    Please may I have a copy too please. Cheers!
    bmacavanza*gmail.com
    Jan 2010
    #13595
    HTH.
    [SIZE=1]3652
    [/SIZE]
    It worked! thank you sir! I tried testing na all the fuses and gumagana sya..i was thinking na nga na ipatanggal ang radio then dalhin sa service center.
    Reset lang pala ang kailangan nya
    Thanks a lot!
    Aug 2005
    #13596
    Iyong softcopy ng manual ay electrical/wiring manual lang siya na napadala ko last year.
    Jan 2010
    #13597
    inquiry lang mga sir
    i was back reading a couple of days ago at may nabasa ako tungkol dun sa philips extreme bulb H4. may nakita kasi ako sa may araneta. HID na daw siya at di ko na daw kailangan ng ballast palitan ko lang daw yung bulb dun sa headlights ko. P1.4k daw for the pair. may nakasubok na ba nito?
    Sep 2005
    #13598
    hindi sya HID.. regular H4 bulb lang sya.. maliwanag lang sa ordinary H4..
    Aug 2005
    #13599
    Quote Originally Posted by mykelA75 View Post
    halogen pa rin ang Philips xtreme. halogen ang stock HL bulbs ng avanza. around 1.4K talaga ang selling price.
    mas maputi ang philips xtreme kaysa stock pero mas maliwanag.
    may thread na dito sa tsikot about this bulb. Ito rin ang gamit ko.
    Jan 2010
    #13600
    thanks mga sir!
    try ko din tong bulb na to
