Page 1369 of 1497 FirstFirst ... 126913191359136513661367136813691370137113721373137914191469 ... LastLast
Results 13,681 to 13,690 of 14970
    Jan 2010
    #13681
    hello po... I already changed dealer and and I will have my new avanza j this friday....yahooooooooooo.
    Jan 2010
    #13682
    Quote Originally Posted by Islaw*Palitaw View Post
    Give them a day or two to produce a unit , otherwise cancel your transactions with that dealer and tell them that your switching dealers who has your preferred choice... matataranta yang mga sales people na yan kasi instead na instant sale na nila, mawawala pa. At wag kang magpapadala sa mga promised freebies until andyan na talaga yung unit mo, some sales people promises a lot of freebies just to retain their prospect to wait for the unit.
    thanks sa advise sir... I already cancelled it and change dealer and I will get my avanza j tommorow....
    Aug 2005
    #13683
    Quote Originally Posted by chervinchoi View Post
    nice. :D
    Congratz!
    #13684
    Originally Posted by xda2jojo
    What I know mahirap i-adjust ang HL ng avanza natin using HID w/o projector.
    Kung ma-adjust man, baka naka HID na ako ngayon, hate people using HID na nakakasilaw, kaya ayaw ko mapabilang sa kanila.
    Sarap pa naman mag HID, less load eto sa batt natin, and the same time more brighter.
    Kaya ipon muna ako pang Projector...
    sir jojo madali lang mag adjust ng angle ng headlamp
    cut and paste ko na lang dito yung post ko sa headlamp upgrade thread
    share ko lang dito tinuro sa akin ng Toyota Bacolod technician kung pano mag adjust ng angle ng headlamp ng avanza, pina adjust ko kasi headlamp ko kasi masyadong mababa yung ilaw ng HID ko. Tools needed, one philips screw driver, isang flat na wall, masking tape or pencil or marker. park your avanza facing a flat wall then turn on your headlight, mark the topmost edge of the light with a masking tape or pencil or marker, adjust the headlamp angle to desired position. hope this is helpful.
    heto yung guide slot para sa philips screw driver
    insert the philips screw driver to the guide slot then turn clockwise or counterclockwise
    adjusting the driver sige headlamp angle
    HTH, bili ka na ng HID
    Aug 2005
    #13685
    Pag gumamit ng HID sa reflectors, nawawala ang cut-off ng HL. so kahit anong adjustment, nakakasilaw pa rin. I think it ang sinasabi ni xda2jojo.
    Now kung mayroong casper shield, possible na bumalik ang cut-off.
    #13686
    yup yan ang ibig kung sabihin, basag parin eto.
    Feb 2010
    #13687
    hi guys. my avanza j cabin has been smelling gasoline for the past 2 or 3 weeks now. The smell intensifies specially after a full tank. What could be the possible problem?
    #13688
    boss mel and sir jojo, the HID am using is ACDelco with high and low beam, it was bought in Dubai and it already comes with a casper shield with a cone shield in front, when i first installed it i have difficulty seeing people or objects 10 meters (in low beam) infront and to the side if because of the short throw of the beam, i tried removing the casper shield and went for a test drive, the lighting was great you could see far beyond but the problem is i am blinding the incoming vehicles (i noticed this because most of them were flicking their headlight and i could see objects as high as 12 ft up because you could see the top of tall delivery trucks) so i put back the casper shield and went to toyota bacolod to have my headlamp adjusted, now visibility is good and i could now see people or objects to the right or left of my avanza and so far no complaints from incoming vehicles. some car owners using HID's remove their casper shield in purpose to give them a much brighter beam but this action is very irresponsible and dangerous for incoming vehicles. installing HID's with casper shield is not enough, you must adjust the beam to the right angle so that you don't blind incoming vehicles.
    #13689
    Thanks sa info sir mikibabs,
    Add ko lang sa avanza HL natin ay "Multi-Reflector" eto, kaya I am assuming na basag ang liwanag using HID w/o projector.
    With you info/tips...mag HID na ako.
    Question:
    Ilang "K" ang HID mo bos?
    [edit1]
    got a 2nd thought here, mainit sa LTO ang HID dito
    (Actually medyo damay kami dito sa mga convoy of black cars last 2~3months ago dahil sa illegal blinker and wangwang, kaya damay ang fog lamp-HID or not and HL HID)
    But i take a chance....
    [edit2]
    Walang HID Sa ACDelco dito:
    http://www.acdelco.com/searchsite/?q=HID+LIGHTS
    #13690
    sir jojo, yung original na bulb ng ACDelco ko is 5000k but my uncle had it replaced to a much lower bulb around 3600, the color of the beam is not pure white but with a little bit of yellowish. i think you won't find the ACDelco HID kit in their website kasi HID is not legal sa U.S. sa pagkakaalam ko, i tried looking it up before sa website nila but my uncle told me not for U.S. market talaga yung HID nila pero very popular daw ito sa Dubai. hanapin ko yung box and look for the model number paguwi ko ng bacolod then post ko yung pix or info.
