Results 13,581 to 13,590 of 14970
- Jan 2010
- 4
January 25th, 2010 08:35 AM #13581Good Day!
can somebody help me?i dont know what to do... bigla na lang namatay yung radio ng 1.5 avanza namin. I don't know if fuse lang sya or what... can somebody send me kung saan ang location ng fuse nya? nabasa kasi yung manual ng avanza nung bagyong "Ondoy" and i've been trying to find a copy of the manual sa internet kaso wala.
any suggestions din kung anong dapat gawin sa kanya..
thanks a lot!
- May 2007
- 401
January 25th, 2010 09:10 AM #13582Any of you guys have an idea how much ang pms (30,000)km sa toyota? Tsaka ano usually kasama sa 30,000km check up?
Thanks.
January 25th, 2010 09:25 AM #13583
I do not have the manual with me. I can check tonight unless some one gets to answer your query.
But there is a main fuse and a smaller fuse after the Acc switch of the ignition. The main may be located at the engine bay. the smaller fuse may be below the steering wheel left side.
January 25th, 2010 09:28 AM #13584
- Jan 2010
- 4
January 25th, 2010 09:32 AM #13585
January 25th, 2010 09:35 AM #13586
Also the 2009 J model sir,
Eto gamit ko FM Modulator, bought from cdrking, 480 lang, same products na benta sa mga car accessories shop na almost 1k.
Gamit dito ang USB flash drive and SD Card with MP3
Near to clutch pedal, may fuse box dyan, hanapin mo ang fuse na ACC 7.5A
Yong fuse na color red(7.5A) nasa upper right next sa color blue(15A)
Wala sa Manual ang location ng mga Fuse.Last edited by xda2jojo; January 25th, 2010 at 09:41 AM.
January 25th, 2010 09:42 AM #13587
- Jan 2010
- 4
January 25th, 2010 10:20 AM #13588thanks! cge check ko na lang...sana nga fuse lang ang problem...wag naman sana yung radio...update ko kayo if ok sya.
thanks a lot xda2jojo and meledson
January 25th, 2010 02:47 PM #13589
Suggestion ko, try resetting the HU muna, poke the reset button with a pen tip or a paper clip, and see if it wakes up. You'll have to set it up all over again, though. The reset button is recessed, next to the 6th memory button (lower right corner).
That's what I do when my Kenwood DPX-MP2090 goes into a coma. Unfortunately, it happens sooooo often that I've resigned myself into accepting the chore of resetting it almost 3 times a week. :cry:
Sometimes nahuhuli ko siya (parang may Christmas lights ang display niya), I just push firmly but very fleetingly either the area of the MENU button, or the volume control button/dial. Minsan I have to push the whole unit to the left and/or right para lang mag-behave siya. Haaay naku.
HTH.
[SIZE=1]3652
[/SIZE]
January 25th, 2010 04:21 PM #13590
Sir Pres, kung pwede, pa email naman ng manual sa dfcs*dfcsantos.com. Na-Ondoy din ang manual ko.
Thank you!
Yikes that(tesla) is even worse although upon some additional reading i'm not even sure our Seagull...
BYD Seagull
