Results 1 to 9 of 9
October 13th, 2003 11:53 PM #1
Hi,
Sino sa inyo meron GSX or GLX na meron Alpine 7871R na head-unit?
Yung sa amin eh meron static noise sa speaker pag ni-operate ang mga power side view mirror (left button only), Aug2003 model nito..
actually paglabas ko pa lang ng casa eh meron na nito... then sa Toyota Makati eh meron silang 21 brand new revo gsx na di pa nabibili at naka park lang ay meron din daw defect yung isa out of 21 at na-inform na raw planta ng toyota.. di mahanap ng Toyota Makati yung problem at babalik na naman ako tomorrow para iwan sasakyan namin..
para mapalabas static noise
1) kelangan tahimik paligid, ilagay sa low of i-off ang aircon
2) naka-close lahat ng windows
3) i-set ang Alpine 7871R sa isang FM station at volume level 1 .. pag nasa level 2 eh mahirap na palabasin static noise...
4) i-operate ang power side-view mirror at pakinggan ang mga speaker... meron ka maririnig na noise (motor noise siguro) sa mga speaker ..(yung sa amin eh left keypad ng side view mirror sa dashboard)
5) although pag malakas na yung radio kahit volume level 5 eh di mo na maririnig yung static noise..
ang sabi ko toyota eh baka kulang or sira yung noise suppressor ng Alpine stereo or baka sira yung motor ng side view mirror.. pero wala at mukhang di ako na-gets.. bahala na daw ang mga electrician/mekaniko nila hayyy..
October 13th, 2003 11:58 PM #2
Does it really bother you on most days? Because if it doesn't, better not risk getting other systems damaged by having the OJT's at Toyota open up your REVO.
My left tweeter has some static, too. Although at low volumes only. I did not find it worth the time nor effort to track down the source of the noise. I just crank up the volume and forget about it.
- 10,620
October 14th, 2003 03:48 PM #5
I also forgot to add that devices such as your head unit are designed to recieve radio waves which may interfere in its operation (this warning is usually written on the chassis of the HU which is buried behind the dash fascia).
October 14th, 2003 04:21 PM #6
I used to have the same problem on my HU (corolla). It picks up the rpm idle of the engine, so kung pabilis ng pabilis ang takbo mo palakas naman ng palakas ang static sa loob ng car... It turned out to be the problem is due to poor connector used on my added amplifier, it oxidized after sometime, nung pinalitan ng gold plated, ayos na.
:worried:
October 14th, 2003 09:44 PM #7
thanks sa mga nag-reply... di ko na nga siguro ibalik sa toyota.. nakaka hiniyang din kasi pag meron minor imperfection yung sasakyan dahil pinaghirapan natin bilhin.. naka warranty pa kasi kaya kinukulit ko toyota na ayusin... sabagay 3years warranty naman at nakaka 2 months pa lang ako
balak ko din kasi palitan yung stock na alpine with another head-unit na capable mag play ng mp3 or wma ..kaya pag binenta or trade-in stock unit eh walang problem...
thanks
October 14th, 2003 11:01 PM #8
Wise decision. :D
Kung makikita mo lang paano humawak ng sasakyan ang mga gumagawa sa CASA... Kahit hindi mo sasakyan yung nakikita mo mapipikon ka talaga...
Bumababa ng rampa ang bilis tapos biglang todo preno kapag nagulat dahil yung kasama niya eh nakanguso at naghihintay sa baba... Paano pa kung hindi nakikita ng mga customer yung area na ginagawan nila...? :flush:
- Nov 2002
- 117
October 15th, 2003 01:11 PM #9Yung SR ko eh defective ang wiring ng front speakers. Same day ng ilabas ko sa casa eh me static na. The next day wala nang tunog, pero me static pa din. The casa electricians discovered that the speaker wiring is touching the door frame (grounded). Kinuhanan muna ng picture, para ipadala sa planta, tapos binalutan ng tape. Mga 1 hour din ang gawaan. I watched them as they do the work....kasi nga baka kung anu ano tanggalin eh. Para na din sigurado na hindi OJT ang gagawa. Naayos naman.
Baka wiring defect din yang problem mo.
got to check one out at sm san fernando today. rear visibility is very poor :twak2: and as typical...
2020 Kia Sonet
