Results 1 to 10 of 10
August 2nd, 2005 08:59 PM #1
Here are some pics that might solve your backdoor noise and squeaks. The noise and squeaks are not factory defect, regular maintenance lang po ang kelangan.
Post your comments/suggestions kung mali po yung mga terms/words na nakasulat. The pictures are also available on the Photo Section of the revo yahoogroups (TROC).
August 2nd, 2005 09:00 PM #2
here's the additional pics..
pag-pudpod na yung black plastic, have the whole hinge replacedLast edited by revoGSX; August 3rd, 2005 at 03:33 PM.
- Mar 2006
- 2
March 28th, 2006 03:16 PM #3I also have a similar problem with my pop's Revo SR. For some weird reason, pag naka-ignition na, naka-ilaw yung "Door Open" warning light, and the most common reason is an "open" rear door--eh madalang naming binubuksan yun. Bakit kaya...?
March 28th, 2006 03:48 PM #4
di ba may limit switch iyon? ..try mo adjust iyon baka kahit naka close na ang rear door ninyo pero hindi niya inaabot mabuti or sagad ang switch para mag off ito,ganito din problem sa revo ng pinsan ko . pag normal lang ang pagsara ng door naka 'ON' pa din ang sa panel ,but once nilakas ang pagsara doon lang nag switch OFF ang Door Open indicator light
March 29th, 2006 02:09 PM #5Originally Posted by kenshinflyer
- Mar 2006
- 2
March 29th, 2006 02:09 PM #6Nanotice ko nga, parang bukas pa rin kung bubuksan yun. Wear and tear siguro... 'Di naman ganun before.
March 29th, 2006 02:24 PM #7Originally Posted by kenshinflyer
sa 1st click, ilaw pa din yung 'door ajar' light
sa 2nd click, di na po dapat ilaw yung 'door ajar' light
then don't forget to open the back door before ninyo isara ng tunay.. hehe
- Jan 2010
- 1
January 8th, 2010 07:39 PM #8
- Sep 2006
- 6
August 6th, 2015 12:18 AM #9Sir hindi ko ma download yung picture on how to adjust yung backdoor ng revo. pls send via email perci_racho*yahoo.com. thanks thanks
- Sep 2006
- 6
August 6th, 2015 12:22 AM #10Sir how can I download the picture on how to adjust the backdoor? can you pls email those pictures perci_racho*yahoo.com. thanks thanks
high idle RPM at engine start
