Results 1 to 7 of 7
    Jul 2003
    ano magandang fluid para sa leaking power steering system ok ba yung mga Power Steering Sealer na mabibili?
    Quote Originally Posted by acenie View Post
    I will suggest na ipaggawa nalang ang leak kesa umasa sa mga power steering sealer na nabibili. Band aid solution lang kasi ang mga yan for me.
    Feb 2005
    I used Cyclo Power Steering Stop Leak before. While it doesn't really totally seal it, the leak considerably slowed down. Ok siya for a few cycles while you save up money to buy a repair kit. However for long term purposes, syempre better parin ipagawa.
    Jul 2003
    Quote Originally Posted by kotiko View Post
    Sabi yumg mekaniko ko rack n pinion daw meron bang repair kit
    Meron yan sir, basta matyaga shop, madaming makukuhanan. Sana magaling din yung shop, hindi din kasi basta basta magpalit ng o-rings nyan, kung di na prepare ng maayos like grinding or polishing ng moving parts, madaling masisira din yung o-rings. I also agree to the posts above, better have it repaired than applying a band-aid solution. Good luck
    Jul 2003
    Quote Originally Posted by jvnj View Post
    ok sir thanx.
    Jan 2016
    Better yet, gaya ng sabi ng iba, maigi pa ipaayos n yn pero check with your mechanic. Kung masyado malakas ang tagas e wag mo ng patagalin.
power steering leak
