Results 1 to 10 of 13
- Mar 2007
- 6
February 10th, 2012 03:39 PM #1mga master bago lang ako. bumili ako ng Toyota Corolla XL 1997 nililinis ko sya kahapon. i started ng engine nagtaka lang ako bakit di umiikot yung fan ng radiator ko? normal ba yun? sabi kasi ng pinagbilan ko normal na laging nasa gitna yung temp gauge ko pero di raw nag ooverheat yun, never kopa na drive ng malayuan. anu po ba advice nyo sakin mga master?
February 10th, 2012 03:49 PM #2
umiikot un fan mo, mag panic ka pag ung needle ng temperature mo nasa 3/4 na, tumaas sa 1/2
February 10th, 2012 04:06 PM #4
- 52,731
February 11th, 2012 06:03 PM #5i would not worry if the fan stays off when starting the cool engine in the morning. modern cars have thermostats controlling their fans. these fans will turn on, once the engine runs and reaches a certain hot temperature. after the engine cools and the temperature falls to a certain level, these fans will automatically turn off. now, some owners have bypassed the thermostats, for reasons only they can fathom. these fans are always on. sometimes, the fans or the thermostat sending units become defective. when this happens and you don't observe your temp gauge, the engine will overheat..
the normal temperature range is when the needle is about the center, give or take a little over or under.. i would worry if the needle goes 3/4..Last edited by dr. d; February 11th, 2012 at 06:09 PM.
- Apr 2012
- 1
April 7th, 2012 10:31 PM #6
- Apr 2011
- 66
April 12th, 2012 09:39 PM #7if you want to see if it turns on, drive it around until it reaches operating temp. Stop in a safe place and pop your hood, and wait for a few mins for the fan to automatically turn on and off. The thermoswitch turns on at approx 92C coolant temp.
- Sep 2010
- 9
April 13th, 2012 04:03 PM #8Ano po kaya ang sira kung di umiikot ang radiator fan kahit mainit na ang makina? sinubukan ko paandarin gamit ang stick ng barbeque umandar sya tapos nung nag-auto off kasi medyo lumamig na yung radiator, di na ulit nag-automatic on kasabay ng fan ng aircon. ano po kaya ang problema, carbon brush? salamat po.
- Apr 2011
- 66
Xiaomi E-Car
