Results 11 to 13 of 13
- Apr 2016
- 2
April 19th, 2016 08:11 PM #11Hello, I have the same problem with my Corolla 97 (carb type)... radiator fan isnt working.. already replaced the fan motor and a fuse... When I did this, it turned on for a bit but then it stopped, and hasnt worked since. I know it overheats kasi lumalagpas sa middle range yung temp nya.. Had a friend checked on it kanina, sabe nya baka relay sa fuse box and blown... Are there any other possible causes i need to look into? BTW, havent replaced, or tested yung relay yet.. Hope someone can help me
- 52,731
April 20th, 2016 12:09 AM #12
April 25th, 2016 11:32 AM #13
Are you sure that the fan isn't working?
Just a suggestion... When the temp goes up, open the hood and check...
If the fan is not working... Must be a temp gauge (or) relay issue...
Another suggestion... Bring water. You can pour it to your radiator when the temp goes up.
If both fans are working and your temp still goes up... Then you have another problem.
high idle RPM at engine start
