Results 1 to 3 of 3
- Feb 2008
- 2
March 14th, 2009 03:21 PM #1hi all...
ask ko lang owners of rav4 (2006-2009) about yun power steering indicator sa dashboard....ngayon ko lang kasi napansin na if you turn the key to ON..lalabas yun mga lights, tapos mawawala...then pag nag start mo na engine, the P/S light comes on again then after few seconds nawala ulit...ganun din ba sa inyo?
also, yun fuel gauge, ganon din..pag nasa ON yun key, it goes up and stay steady...pero once you start the engine, pipitik siya ulit pababa then aakyat ulit...
lastly, is using e-10 fuel better than unleaded?
hope you guys can share kung ganon din sa inyo para malaman ko kung normal lang ito...if not i have to bring it to the casa habang nasa warranty pa..thanks!
March 14th, 2009 05:08 PM #2
March 17th, 2009 03:44 PM #3
pag naka on sa key lahat nang ilaw lalabas pero once na start mo na mawawala na tapos hindi na lalabas ulit
hindi ako gumagamit nang e10
high idle RPM at engine start
