Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 59
    Worth of 1k ang naikarga,
    Don't know if it's a driver(lady) fault.
    Biglang umitim ang lumabas sa exhaust then di na umandar.
    Pinadrain na ang lahat nasa fuel(naka-tilt up ang front side).
    Tanong: Ano ang possible na masira?
    Quote Originally Posted by xda2jojo View Post
    Don't worry bro.
    Walang masisira riyan. Lagyan lang ulit ng gasolina, after ma-fully-drain.
    Takbo ka na....
    Mas delikado ang diesel na nalagyan ng gasolina....
    13.2K:boxing:
    Jul 2010
    +1000 ke broCVT.......
    Aug 2010
    Still, I find the entire situation funny.. ano kaya reaction ni xda yun nalaman niya.. must be: "<insert expletive>, bat mo nilagyan ng diesel eh gasoline yan?!"
    Bro CVT, paano mo nasabi that a diesel-engine fed gasoline is worse? Piqued my interest tuloy
    Jul 2010
    Aug 2004
    Diesel in a gasoline engine: Since diesel won't ignite when the spark plugs go off... it won't explode. It'll die on you. Clean off the plugs, drain the fuel system, and you're all right.
    Gasoline in a diesel will, over time, destroy the fuel pump as it dries out the lubrication. If you run it long enough, the lack of lubricity will also the inside of your engine. If you fill a nearly empty tank of diesel with gasoline... then that's even worse...
    I shudder to think about what it'd do to the sensitive components of a direct injection (CRDI) diesel... but the same can be said, I guess, for diesel in a direct-injection gasoline motor...
    ^ nice one bro DF.
    kaya ako....pag nagfi-fill up, naka tingin ako sa attendant kung ano ilalagay nyang fuel sa tsikot ko.
    Jul 2010
    ^ nice one bro DF.
    tenchu broRT...delikado talaga sa mga me diesel engine sa pagkakarga ng fuel.....kailangan extra ingat...laking gastos kaya yan....
    Happened to our Corolla before. We just drained the tank, carb and cleaned the plugs and all was well.
    Dapat nilalagyan ng sticker na "Gasoline" (na may picture ni Calvin na nag-weewee). :D
Accidentally fill diesel in a gasoline car(Innova)&#8206;
