Results 1 to 20 of 59
    Worth of 1k ang naikarga,
    Don't know if it's a driver(lady) fault.
    Biglang umitim ang lumabas sa exhaust then di na umandar.
    Pinadrain na ang lahat nasa fuel(naka-tilt up ang front side).
    Tanong: Ano ang possible na masira?
    Quote Originally Posted by xda2jojo View Post
    Don't worry bro.
    Walang masisira riyan. Lagyan lang ulit ng gasolina, after ma-fully-drain.
    Takbo ka na....
    Mas delikado ang diesel na nalagyan ng gasolina....
    13.2K:boxing:
    Jul 2010
    +1000 ke broCVT.......
    Aug 2010
    Still, I find the entire situation funny.. ano kaya reaction ni xda yun nalaman niya.. must be: "<insert expletive>, bat mo nilagyan ng diesel eh gasoline yan?!"
    Bro CVT, paano mo nasabi that a diesel-engine fed gasoline is worse? Piqued my interest tuloy
    Jul 2010
    ^ nice one bro DF.
    Oct 2013
    Roska,who never came down from up stairs,suddenly ran into the dining room they began to chase her out she was scared,doubled back into the room and sat down a footman picked her up and carried her away When after fifteen years of married life he died leaving her with a son and two daughters,Marya Dmitrievna had grown so accustomed to her house and to town life that she had no inclination to leave O
    Air Jordan Pas Cher
    Aug 2004
    Diesel in a gasoline engine: Since diesel won't ignite when the spark plugs go off... it won't explode. It'll die on you. Clean off the plugs, drain the fuel system, and you're all right.
    Gasoline in a diesel will, over time, destroy the fuel pump as it dries out the lubrication. If you run it long enough, the lack of lubricity will also the inside of your engine. If you fill a nearly empty tank of diesel with gasoline... then that's even worse...
    I shudder to think about what it'd do to the sensitive components of a direct injection (CRDI) diesel... but the same can be said, I guess, for diesel in a direct-injection gasoline motor...
    Oct 2013
    good to me It is not so much the lack of technical information that holds us back,but more the lack of self confidence The closer he gets to good bye,the more he seems to remember this example while thou art employed in the perusal of the following sheets.and seek not to appropriate to thyself that which equally belongs to five hundred different people
    Air Jordan Pas Cher
    Diba inuulit-ulit naman ng gas boy kung ano ikarga sa kotse mo? Meron pa nga pinapakita na parang tag eh
    Kaya ako as much as possible, sa isang gas station lang nagpapakarga, kilala na den ng mga attendants yun sasakyan ko, alam na nila ano ilalagay, syempre i double check den naman..and in fairness w/ the gas attendants, nagdo-doublecheck den naman sila..
    Jul 2010
    wahid tisaeen - 91
    or
    kamsa tisaeen - 95
    eto lang sasabihin mo sa gasboy......
    diesel(bihira ang available sa mga city) mostly sa mga highways...
    share ko lang mga braders and sis...
    happened to me last year. nagpakarga lang ako ng worth 300 pesos dyan sa may TM Kalaw madaling araw kasi noon, baka kako maubos e sa may macapagal talaga ako nagpapakarga. Sinabi ko sa gasoline boy, diesel, nakasulat din sa may cap ng gas tank yung diesel. Tumatakbo yung makina ko kasi nagmamadali ako aabutan ng coding, nung isasara na ng gasboy yung fuel tank, sabi. " ay diesel pala" kaya pinatay ko agad yung makina. Matigas pa yung gasoline boy nung una, me CCTV camera yung gas station. Nakayapk pa yung gasboy at mukhang me tama, which is a clear violation of their workplace procedures. To cut the story short, pina drain namin sa casa yung fuel tank, di ko pinahatak, pina piggy back namin sa tow truck. Mabait naman yung manager ng gasoline station, mukhang may previous record na ng negligence yung boy, umabot ng mga 8K PHP ang expenses nila, which includes cost of draining ng fuel lines, towing at free full tank of diesel. Ang ride ko, Hyundai Tucson AT - CRDI. Ang pinakakabwisit ko dun, one week lang ang vacation ko dyan, nasayang pa yung isang araw since almost whole day ang service dyan sa mag Hyundai Macapagal.
    Ang gas pump nila e yung nakasabit kaya di mo alam kung alin dun ang gas o diesel.
    Lesson learned, wag papalit palit ng gas station hanggat maari, bumaba sa sasakyan at tignan mabuti kung ano ang ikinakarga sa oto mo.
    salamat sa mga reply guys,
    ganito nangyari kanina,
    biglang pinara ang bro ko ng isang tsiks malapit sa gas station.
    pumara naman ang bro ko na akala baka kakilala lang.
    yon pala nagpatulong dahil di umandar ang innova nya.
    sabi nya umandar naman pagkatapos nya nagpa-gas, kaso itim ang lumabas sa exhaust then biglang di na gumana, kahit ilang start....
    tanong ang bro ko kung ano ang nasa resibo, may nakitang diesel worth 1000pesos.
    tanong uli ang bro ko kung diesel ba ang sasakyan nya, sabi ng tsiks, gasolina...
    naabutan ko pa eto na naka tilt sa approach ng gas station para madrain lahat laman.
    nagpapatanong kasi ang tsiks kung ano ang possible masira....
    everytime na nagpapa gas ako, kinuha ko talaga ang resibo to double check kung tama ang fuel na nilagay, aside sa nakikita kung color green na noozle which is unleaded...
    yong bang dito sa atin iba ang dimension ng filler for diesel and gasoline?
    Dec 2007
    Sangayon ako na bantayan na lang ang tsikot pag nagpapagas. Baka yung fuel cover din di maibalik.
    agree ako sa yo shadow. usually, papakita pa nila yung pump...naka-zero yung no. of liters tsaka amount.
    sasabihin pa kung ano ilalagay nyang fuel sa tsikot mo.
    Oct 2013
    This poultice was scarce laid on,when the drummer,who had begun to abate of his exclamations,broke forth into such a hideous yell as made the whole company tremble,then,seizing a pewter pint pot that stood by him,squeezed the sides of it together,as if it had been made of pliant leather,grinding his teeth at the same time with a most horrible grin At length,it was proposed by Bragwell,that we should scour the hundreds,sweat the constable,maul the watch,and then reel soberly to bed
    Air Jordan Pas Cher
Accidentally fill diesel in a gasoline car(Innova)&#8206;
