Palyado parin sa umaga at puti ung usok,
-new carburator
- platinum sparkplug
- tension wire
- vave sael
- cylinder head gasket
tulong po mga sir sa may alam nito.. God bless!!!
-new carburator
- tension wire
- vave sael
1. Tingnan mo ang tailpipe mo kung malagkit ang black soot which indicates me kahalong langis yan
2. Bantayan mo ang oil level mo kung bumababa.
Sa pagka alam ko, ang cause ng white smoke sa exhaust is that your engine is burning oil. The culprit here maybe worn piston rings, or damaged pistons or cylinders which allows oil to infiltrate in the cylinder to be burned, hence the white smoke on the tailpipe.
try mo nga to ibilad mo sa araw ung oto mo sa kalye hanggang mag tanghale tapos istart mo, tignan mo ung tail pipe kung may white smoke pa,, morning malamig may moisture??
thats normal. steam lang yan. matakot ka kung tuloy-tuloy ang white smoke. overhaul yan kung sakali
