Results 1 to 5 of 5
- Mar 2005
- 5
June 21st, 2011 10:47 PM #1Hi to all!
Help lang mga sir... Pina-check ko yung revo SR gas namin (7K engine) kasi medyo malakas na sa langis and mataas na sa emission test nung ip-rehistro ko. Pansin ko din mas malakas na sya mag-consume ng gas. Sabi nung mekaniko, kailangan na daw dukutin yung makina. May mga binanggit sya na papalitan na mga pyesa like timing chain, gear sprocket, overhauling gasket, piston ring. Nag-quote din sya ng labor, nasa 5K daw. He also told me na baka daw palitan yung valve lifter, eh may kamahalan ata yung valve lifter, nasa 900 each daw and if ever, walo daw yun.
Tama ba mga sir assessment nung mekaniko? Di ko ma-recall yung iba pa mga pyesa na papalitan eh, pero nasa 15K pesos na yung list na ibinigay sa akin. All original parts daw kasi. Kung replacement parts ang gamitin, okay din ba?
Any help would be highly appreciated.
Thanks!
June 22nd, 2011 10:11 PM #2
Mas ok sir mag pa 2nd or 3rd opinion ka pa sa ibang mekaniko, saka ka magbase kung anu ang mga assesment nila, even matagal mo na din kilala yung mekaniko mo, mas ok na meron ka pa ding opinion sa iba, di mo pa din masabi yung mga dapat palitan na parts kung di pa nabubuksan, kung iisa ang sinabi nila, saka ka magdecide sir, kung sa parts, prefer na orig parts ang ipalit mo, sigurado ka na tatagal, mahirap mag palit kung replacement parts sa loob mismo makina, baka di tumagal, doble lang gastos mo sir
- Mar 2005
- 5
June 24th, 2011 08:37 AM #4
Parang mahal ang singil niya for labor alone. Get first an compression test done to see what part exactly has to be replaced (i.e. piston rings, head gasket, etc.) then canvass for the parts on your own in Banawe.
Kung malakas din sa gas consumption and the emissions isnt good, then have your carburetor checked and overhauled/adjusted if necessary. There are carb specialist shops located on Kamuning Road who can do the work easily and within budget.
June 24th, 2011 08:50 AM #5
pag open na engine, i would advise na palitan na din yung mga dapat palitan para isang trabaho nalang... wag magtipid, mas lalaki ang gastos pag after few days or months you have to re open it para don sa parts na hindi pinalitan...
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
