Results 21 to 30 of 44
- Dec 2009
- 242
May 4th, 2010 11:23 PM #21Thank you all for the inputs. Overhaul, ouch! Hope it's something else but if clutch is really the problem then so be it. It's fine for me to spend for a fix the will make that problem go away. What's frustrating is the casa/technician make you spend and spend but the problem is not getting solved just like what the casa I've mentioned did to me. I've spent P9,200 already but I'm not seeing light at the end of the tunnel so to speak. It made me doubt so I backed out and learned that somehow I need to have ideas about the problem. That's why I posted this problem here hoping I can learn from experienced people like you and I did. So thanks again. I'm planning on taking the car to Toyota service center which I think is my best bet otherwise if you could recommend reputable transmission technician/casa out there then I would greatly appreciate that.
May 5th, 2010 12:01 AM #22
^^ better buy a surplus Automatic tranny than to overhaul. halos di nagkakalayo ng presyo.
May 5th, 2010 05:00 AM #23
- Dec 2009
- 242
May 9th, 2010 07:48 PM #24Bad news from Toyota Pasig, ECU na pang manual daw nakakabit sa car. :whoa: To verify I checked it out myself, the attached label shows the model is 89661-02870 and there's also caption 3ZZ-FE M/T. I also did some research through the internet and it appears that indeed it's for manual tranny. I would like to verify from you guys as well if you happen to know that specific ECU model. More importantly, I would like to know if it does makes sense that it is the cuase of low power. Cause if I have it replaced and there's more to fix then I'll consider other option.
May 9th, 2010 07:53 PM #25
^^ thats really a sucker samcoy. sorry to here that, i'll check tomorrow morning whats written/labeled on my ecu. i have an altis on 3zzfe MT.
so maybe, your car is a ondoy victim.
May 9th, 2010 08:09 PM #26
Sounds like a failed attempt at restoring it after the flood.
I would bring it back to the seller. Given the circumstances, I think it wasn't sold to you in good faith.
- Dec 2009
- 242
May 9th, 2010 09:02 PM #27Thanks sir! I'll wait for your update. May kilala ka ba na may matic? If you can do me another favor or somebody else here can you give me the model of ECU?
probably, actually that's the conclusion of Toyota. To be honest, I doubted them at first thinking they're just trying to sell me their stock but after seeing it myself now I'm convinced.
- Dec 2009
- 242
May 9th, 2010 09:09 PM #28
- Dec 2009
- 242
May 9th, 2010 09:34 PM #29Just wondering how come the car can upshift and downshift with manual ECU unless they did some modification. Any idea?
- Dec 2009
- 242
May 17th, 2010 05:13 PM #30
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
