Results 1 to 10 of 11
October 10th, 2006 02:40 PM #1
may nakasabay akong toyota prado kanina sa car wash. 3.4 V6 sya. sabi nung owner local daw yun. but i think otherwise, kasi the antenna is located on the driver's side.
did TMPI release a gas prado locally?
October 10th, 2006 04:44 PM #2
Is this the new body or old body? The local ones i'm sure were released were diesels.
October 10th, 2006 04:48 PM #3
the old body (LC90 ba yun?). 1999 daw nya nabili. i really doubted na local yun, pero hindi na ako nakipag argue. hindi ko naman sya kakilala
October 10th, 2006 05:20 PM #4
Not sure about being local, but Prados did have their antennaes mounted on the driver's side. Reason being so that the driver could reach it (for non-power antenna equipped units). Since they share the same mounting holes, even units with motorized antennaes are still mounted on the driver's side fender.
Tsikot Member Rank 5
- 3,144
October 10th, 2006 05:33 PM #5karamihan nyan nakikita ko sa tektite, may mounted na yellow auxlight. color green with body sticker...
at nakalagay v6 3.4
October 10th, 2006 06:21 PM #6
hmmm.... nangangarap na orig LHD ang nabili at hindi galing subic???? ahehehehehe
October 10th, 2006 10:56 PM #9
yes, im sure there were 3400 v6 gas prados sold. just look at the plate and you'll know if converted yun.
October 10th, 2006 11:11 PM #10
yup the 3400 V6 sa gilid may stickers yun.
tama rin si sir Otep, sa left talaga ang antenna nya.
WIK, its the same 3.4L V6 from the USDM Toyota 4Runner from 94-99 i think.
basta, 178hp ata yun.
high idle RPM at engine start
