Results 111 to 120 of 1628
October 29th, 2007 01:29 PM #111
November 1st, 2007 07:09 PM #112
Gentlemen, Can you help me with regards to D4D Problems, I am planning to purchase a Toyota Innova G Diesel Automatic but I am afraid sa mga problems na naeencounter ng iba having D4D problems...
Until now ba meron pang ganun na makina ang Toyota Innova?
November 1st, 2007 07:40 PM #113
So, you've decided to get an Innova instead of a pick-up?
Well to answer your query, usually po kasi ma'am yun na-encounter na problems sa D4D e sa mga naunang units ng Innova. Mostly 2005 and a few 2006 models. Although it still has to be confirmed, the culprit is the CRDi and the quality of diesel used. If you read a few posts back some tips where given by dieseldude to minimize or eliminate this problem.
Pero I won't guarantee that it will not happen to any new unit. I kinda liked the Innova kya yun ang kinuha ko. I have my fingers crossed nga when I got mine... and I even had nightmares about it. haha
But just as BoyT said "Just enjoy the ride"... and that's what I did.
HTH
November 2nd, 2007 12:07 PM #114
November 2nd, 2007 12:27 PM #115
mam behn, since you are from valenzuela city, maybe you can PM larshell and ask about his innova. pwede rin sigurong test drive. basta sa kanya ka lang magpapakarga ng shell.
November 3rd, 2007 09:24 PM #116
I have my Innova for more than a month na po, I've been using it going to Pangasinan, Isabela, Nueva Vizcaya, Nueva Ecija, Bulacan, Tarlac and Pasig... so far it handled the terrain well.
Others say that it's still bumpy compared to a car's suspension maybe because of the stiffer coil springs. I used to drive a '96 Nissan Eagle, so compared to that... the Innova's suspension is good enough for me.
And I'm guessing compared to your linx's suspension... the Innova's stiffer coil suspension can handle the weight of the equipments that you usually carry.
November 4th, 2007 01:58 PM #117
Shocks ng Innova ko sira agad. Most of the time ako lang ang sakay.
If you will ask my opinion WAG NALANG INNOVA instead look for a 2nd hand Pajero or Trooper.Walang problem sa off road. Mas safe ka pa. Innova walang protection ang passenger.
Naku bossing walang problema kahit nga sa pinaka walang hiyang driver ko pinapa drive ko na yong innova ko para masulit lang kaso nabenta ko na.
Yong Pajero ko nalang pwede.
November 19th, 2007 06:57 PM #118
Further update. My boss' Fortuner 3.0CRDi, which has stalled on her several times already this past month, is now going to get fixed - no thanks to Toyota Quezon Ave. If my boss hadn't called in a favor with a high-ranking guy from Metrobank, it would have taken at least a month for Toyota QA to change the fuel pump. Their first excuse was that the part was on order and would take that long to arrive. But one call was all it took for the part to miraculously appear in their inventory. Now, the Fort will be good to go by tomorrow, Tuesday. All's well that ends well, I suppose. (If this is indeed the end)
- Nov 2007
- 7
November 19th, 2007 09:04 PM #119I bought an innova e diesel late december 2005. I think I have my computer box calibrated for 2x then replaced supply pump within the first 5000 km.
One thing I hate to say is that the dealer dont allow you to bring your own motor oil when the unit is brought to the casa for regular maintenance saying that your warranty will be voided if you bring your own oil. And during the 1000 km check up, they also want to flush your engine.Will this do good to your car or do more damages to your car during the first 1t km check up. I think Toyota Phils. should reorient their dealer to emphasis on service rather than the earnings they want to dictate at the expense of their client.
November 21st, 2007 06:46 PM #120
Tsikoteers and Innova owners!, Is it true na naayos na problem sa D4d engine ng Innova? I already have a reservation na kasi for an Innova G 2.5 D4D dsl A/T, upon reading the thread parang medyo nagiging skeptikal na ko mag Innova Dsl. Just need your latest inputs regarding the D4D issue. If ok na I'll still stick with the diesel variant since FC is a big big factor to me. If not I can still change my reservation into a smooth Gas ride.
thanks in advance!!!
high idle RPM at engine start
