Results 1,561 to 1,570 of 1628
- Dec 2013
- 14
December 19th, 2013 04:45 PM #1561Mga Sir, help naman po...ung Innova G D4d 2006 is hard starting..hard starting sya kapag naka incline ung parking ko....meaning ung makina ang nasa taas....pero kapag naka park naman sya ng pantay ok naman ang starting niya......nagpalinis na po ako ng fuel tank...nagpalit narin ako ng fuel filter sa fuel pump...din sabi sa akin ng mikaniko ko is palitan ung SCV Kit..pinalitan ko rin sya....pero hindi parin ma solve ung problem ko kapag naka park ako ng incline ayaw talaga niya mag start....always naman puno ang fuel tank ko....pa help naman po....dami kuna nagastos pero hindi parin ma solve ang problema ng innova ko... please mga brader...
- Nov 2013
- 14
December 19th, 2013 05:34 PM #1562hello po, subukan nyo park nyo uli naka incline yung sasakyan; bago nyo i-start i-manual pump nyo yong hand pump sa may fuel filter hanggang maramdaman nyo na tumigas at subukan nyo kung maistart. kung pwede siyang mag-start after manually pumping the hand pump., ibig po sabihin ay may hangin po ang fuel lines nyo. paki check nyo na lang po ang mga rubber hose lines, hose clamps, o-ring sa fuel filter assembly, etc. normally pag hinangin ang fuel line lalo na suction side, dito po nag kakaproblema at hard starting dahil kulang o zero fuel delivery.
- Dec 2013
- 14
December 19th, 2013 06:03 PM #1563
- Nov 2013
- 14
December 19th, 2013 06:20 PM #1564sir sa baguio ako, kung dito lang marami ako mga kaibigang mekaniko na marunong sa d4d.
- Dec 2013
- 14
December 19th, 2013 06:25 PM #1565
December 19th, 2013 08:38 PM #1566
- Nov 2005
- 1,078
December 20th, 2013 04:53 PM #1567Are the new model Innova D4D's still plagued with these problems? Appreciate your feedback. Thanks.
December 20th, 2013 04:58 PM #1568
None that i know of sir.
Sent from my iPad using Tsikot Car Forums
- 52,731
December 21st, 2013 01:56 AM #1569
- Oct 2013
- 1,181
December 21st, 2013 07:40 AM #1570Ipascan mo innova mo, baka may error yan na hindi magmanifest ng check engine light. Kapag hard starting incline, di lang naman fuel line yan. Pwede rin makina mismo.
Sent from my SM-T311 using Tsikot Forums Mobile App mobile app
high idle RPM at engine start
