Results 1,411 to 1,420 of 1628
May 22nd, 2013 02:15 PM #1411
Kahit may catchcan ka pa.. Oil will always be present in your intake manifold.. As long as you connect the crankcase ventilation in the intake, there will always be oil.
Afaik, oil in the intake provides lubrication in the turbo's impeller/blade.
If you want no oil, either you dump the blow-by gasses in the atmosphere or you install a water/meth injection.
- Apr 2012
- 66
May 22nd, 2013 06:36 PM #1412Sir Brian,
Ung 2012 Innova J D4D ko, napansin ko din na nagkaka-oil sa turbo. Pina check ko sa CASA during my 5K PMS. Sabi nila normal lang daw un. Ibalik ko na lang daw sa kanila pag umulit ng ganun.
Pinunasan nila sa casa para matuyo ung labas pero paguwi ko, tinanggal ko ung intake hose at nakita ko na medyo madami ngang oil sa loob. Pinunasan ko na din. Up to now, ok pa naman takbo ng Innova ko
BANNED BANNED BANNED
- Feb 2013
- 487
- Jul 2003
- 2,267
May 22nd, 2013 08:24 PM #1415
May 22nd, 2013 11:44 PM #1416
Correct. Wag lang ung maraming langis. Usually parang nag momoist mapapansin mo dun.
- Feb 2013
- 487
May 23rd, 2013 06:56 AM #1417
- May 2013
- 8
May 23rd, 2013 07:43 AM #1418Good morning mga sirs. Re-post ko lang dito.
May mga tanong ako about what happened to my father in law's fortuner.
1. May thick white smoke na lumalabas pagka start specially in the morning though nawawala after 30 mins or so. Ano kailangan kong patingnan?
2. May leak sa fuel injector pump, saan ko pwedeng dalhin para ipagawa?
3. Saan pwede magpagawa ng remote-key? Sira na pati pindutan.
Salamat!
- Feb 2013
- 487
May 23rd, 2013 08:33 AM #1419
- May 2013
- 8
May 23rd, 2013 10:05 AM #1420Thanks sir siopaonatoasted.
Sir do you know any trusted mechanic in qc other than the casa?
Thanks again.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
