Results 1,291 to 1,300 of 1628
July 4th, 2012 08:51 AM #1291
July 4th, 2012 04:59 PM #1292
It is good that this issue is already a none issue. New Innova owners will now have a peace of mind.
- May 2012
- 21
July 4th, 2012 11:50 PM #1293
July 5th, 2012 12:03 AM #1294
Just let it run on idle for a few minutes then drive slowly for the first few meters. Significant wear and tear happen on initial start when the engine is still cold and when the oil has not yet circulated properly. Most technicians don't know any better as they don't own cars. They were just trained specifically to do the necessary maintenance and repair procedure.
- May 2012
- 21
- Apr 2010
- 156
July 9th, 2012 05:22 PM #1297Sir, bakit kelangan mo mag 2000+ rpm pagka start? Even though pwede mo na siya patakbuhin after cold start after a couple of minutes, better not to rev the engine aggressively, kelangan mo muna ma attain yung proper temp before you could do high revs.
Personally I do not rev the engine pag idle, bukod sa aksaya krudo, unnecessary strain lang yan sa engine on cold start, even bago patayin engine, idle ko muna for about 2 minutes. When you drive after the cold start, be sure to keep the revs very low like <1500 rpm. Sigurado namang aandar vehicle mo kahit mababa rev mo. Ganun din pag malapit na sa destination, di na ako nag rerev past 1500 rpm.
- May 2012
- 21
July 10th, 2012 10:25 PM #1299tinetesting ko lng sir kung matatanggal ung unusual engine noise pag natakbo sa range na 1200 to 1700 rpm lalo na pag nagtse change gear ako from 2nd to 3rd gear pagka release ng clutch mas pakinig yung kakaibang ingay nang makina. paminsan minsan lang nangyayari kaya di ko mapacheck sa casa. baka may alam sa inyo mga sir kung ano pede sabihin sa service advisor na dapat macheck o suggestions po para mawala yung kakaibang ingay. salamat po.
- Feb 2010
- 150
July 11th, 2012 07:16 AM #1300Try mong itaas ng konti yung rpm mo before you change your gear, gawin mong 2000 then observe the engine noise kung ganon pa rin.
Xiaomi E-Car
