Results 851 to 860 of 1628
- Feb 2010
- 150
- Feb 2010
- 150
September 17th, 2010 07:37 AM #852No, the other guy mean, for example you're running on the highway or expressway, or some places where do you think you can shift her up to 5th. gear, kasi once na ginawa mo yung from neutral to 5th. gear kaagad,kakalog ang makina mo at may tendency na mamatay pa ang makina depende sa bitaw mo ng clutch, the reason is, kung manipis na ang clutch disc, once you reach the 5th. gear, instead na bumilis pa sya, babagal ang takbo nya kasi hindi na maka-kapit yung disc sa flywheel or pressure plate, so, shift it to lower gear. You can try also, once you shift to first gear, bitawan mo yung clucth dahan-dahan, normally kung ok yung clutch disc, medyo tumatalon pa sasakyan at saka mabilis reaction nya, aarangkada kaagad yan, pero kung manipis na at sliding, mabagal ang reaction nya, tatakbo pa rin pero malamya or parang tinatamad na tumakbo.
Ang kailangan don, palitan ang clutch disc, pabaklas mo yung transmission, about one day ang consumption sa trabaho don depende pa kung saan ka magpapagawa.
Kasi two times ko nang na-experience yan sa mga sasakyan ko, once na napalitan yung clutch disc nyan, babalik sa dati ang takbo yan.
September 20th, 2010 02:04 AM #853
Hope hinde to OT
If I may ask, if they say na dirty diesel what exactly it means? Dirty in what way?
I ask this because I am working in Military bases, most of available fuel here are what we called JP-8 not lubricated like diesel fuel, JP-8 fuel grade are used in Military vehicles. What we are doing is that we mixed used oil (but it under goes to cleaning, but not as clean as new oil) to JP-8 to make it diesel grade coded DF-2, pero yung used oil na yun came from our power plant generators and we then use the DF-2 to feed our generator ulit and all our diesel vehicles. (sometimes we use pure JP-8 sa mga sasakyan).
Nasabi ko to kasi most of our trucks are Hilux 2.5, Hi-ace, Strada, Ranger and all American trucks na from F250 to 450 also sa may avatar ko Excursion. Ok namanLast edited by isotopes7; September 20th, 2010 at 02:14 AM. Reason: add more
September 21st, 2010 10:03 PM #854
- Sep 2006
- 1,335
September 23rd, 2010 09:20 AM #855
September 27th, 2010 11:10 PM #856
Sir, if I may ask; if dirty diesel is a scapegoat or lets say the lame excuse from the dealer; the real culprit on these then, that, the fuel pump of most Toyota are faulty or not working as to how it is expected to work?
what can be the remedy for these cause, as we already own a Toyota car now!?! we just cant cry over spilled milk on these; do they have any remedial on these? what does the public do about these?
- Sep 2006
- 1,335
September 29th, 2010 08:31 AM #857Sir, if I may ask; if dirty diesel is a scapegoat or lets say the lame excuse from the dealer; the real culprit on these then, that, the fuel pump of most Toyota are faulty or not working as to how it is expected to work? That's how it looks.
what can be the remedy for these cause, as we already own a Toyota car now!?! we just cant cry over spilled milk on these; do they have any remedial on these? Yes, they came up with an improved supply pump. But you have to pay for it....
what does the public do about these? I don't know.
- Sep 2010
- 72
September 30th, 2010 10:48 PM #858Balak po namin bumili ng Hi-Ace GL Grandia. okay lang po ba yun? pagkatapos ng mga nabasa ko parang nakakatakot na tuloy.
September 30th, 2010 11:09 PM #859
- Aug 2008
- 164
October 1st, 2010 03:03 PM #860
Xiaomi E-Car
