Results 771 to 780 of 1628
July 2nd, 2010 11:30 PM #771
thank you sa suggestion.castrol edge 5w-30 is newer oil that is compatible to d4d 2kd-ftd engine... I just purchase Motul specific CRDi 5w-40 today, on sunday ill changed the oil myself.. and see if may improvements compare sa toyota fully synthetic.. my 08innova d4d mt is still under warranty pa naman. kaso medyo hindi worth ang services ng toyota..
mdggapo is your innova AT or MT? how much speed do you get on 2000rpm?2500rpm? on stock 205/65 r15 tires? thanx.
- Jul 2009
- 26
July 3rd, 2010 11:28 AM #772Have you checked your air filter? Try removing your air filter and drive around, look if the smoke decreases. If it does, buy a BNEW Toyota Original Air filter. Never buy replacement for Common Rail engines.
Does your smoke belch problem coincide with a power related problem? or okay naman power mo?
edit: by the way, driving without an air filter is only good if you are diagnosing the problem but it could damage the engine if debris enters your manifold.
July 3rd, 2010 02:58 PM #773
- Nov 2008
- 5
July 5th, 2010 02:34 PM #774hi mates!
just like to share my experience here since dami ko ng time nag-attempt na i-post ito dito at para na din sa kaalaman ng iba pa, marami kasing TMP service center ang walang viewing area para makita man lang natin kung talagang ginagawa nila ung mga concern nating mga owner, so getting my chance i recorded what & how the "Check Engine" problem was diagnosed
mine is 2007 fortuner 2.5 d4d having an exact mileage of 25,500kms. and 36 mos. old na sa akin...i've encountered the same "Check Engine Problem" approx 9,000kms of using my fort, so following instruction written in owner's manual helps me awhile reaching TMP Dasma Cavite and submit my complaint. what they did was dettach the Fuel Cable Connector Line near under the Break Pedal and cleaned the contacts, they attached "Intelligent Tester II" then applies pressure on the Fuel Pedal, and for viewing pleasure here's the link : [ame="http://www.youtube.com/watch?v=_TnRqipBWXY"]YouTube- intelligent tester.mp4[/ame] (related vids kaso japs : [ame="http://www.youtube.com/watch?v=fQNtKAlbirA&feature=related"]YouTube- Toyota Intelligent Tester II[/ame] )
while doing their works my fuel indicator light pops out informing insuficient load on the tank, buti na lang at di talaga ako nagkarga ng diesel before going TMP, i was using PETRON that time
then after performing their works i ask the service supervisor for possible reason/s kung bakit nag Check Engine Light, simply answered me "MADUMI KASI ANG DIESEL NATIN SA PINAS" kaya malamang naapektuhan ang Fuel Pump kaya nagkaganoon.....ignorante ako sa issue na ito kaya smile na lang ako at sa isip ko buti na lang ganun lang, the supervisor told me that the fuel tank still having approx 5 ltrs so for me to reach nearest gas stn. & sabay bulong sa akin "try nyo sa CALTEX" sabay ngiti, so i used Caltex up to now.....maganda ang result using Caltex base sa aking experienced
i clean the Air Filter every other week since i have an air compressor as part of my routine when dusting the engine and already replaced the Air Filter reaching 20k milage, buti na lang nakasanayan ko na cos hindi na pala ginagawa sa kasa ang ganun at pinagbawal daw sa kanila ng DENR, kaya replace na lang sila....ewan ko sa ibang TMP service center
OT : di ko masisi si Mr.Mamawal dun sa ginawang interview cos nakasama ko yan sa work when i was employed at Wyeth Phils., we fondly called him Mr.Bow kasi kahit baluktot ang reasons eh ipipilit pa din...my 2cents, Bobbit no offensement ;)
regards
July 6th, 2010 07:44 PM #775
Toyota Hi-Ace Commuter 2010 D4D nag choke:
After painitin ang engine for 2 minutes, nag first gear ako then arangkada. Parang wala siyang power pero umandar ng konti then tumigil pero buhay pa rin ang engine. Binalik ko sa neutral then nag first gear ule ako then arangkada pero ayaw umandar at walang power hanggang sa namatay na ang engine. After starting the engine parang walang nangyari at umarangkada ng normal. Natakot ako so binirit ko after at wala ng problema. 15000 km pa lang ang tinakbo nito. Last May lang namin nilabas yung van.
July 6th, 2010 09:29 PM #776
- Jun 2006
- 1,139
July 7th, 2010 01:38 AM #777well that busts the myth that CBU japan Hi-ace are immune to D4d problems.
July 7th, 2010 11:56 AM #778
July 7th, 2010 10:02 PM #779
Di pa namin na papacheck kasi di na ulet nangyari. Sana wag na ulet mangyari ang pagchoke.
July 8th, 2010 10:22 AM #780
Xiaomi E-Car
