Results 1 to 17 of 17
    Aug 2005
    Hi guys,
    How is the OIL CONSUMPTION of your LC? Sa amin, you need to top up everytime we had a long run.
    Kamusta yung mga bago?
    I read about that oil consumption problem before.
    But i don't have a LC200 so i can't confirm. :D
    Nabasa ko sa 4x4ph na problem nga daw ng LC200 yung kumakain ng langis. Parang chief mechanic yata sa middle east yung nagpost. Several units na below 3 years old needed complete overhaul.
    May 2007
    No need for overhaul not unless may problem talaga makina mo. You can read the lc200's manual na its normal yun ganyan not just for the 200 but also for fortuner. You need to top up talaga on the 200.
    I cant recall which australian forum i read they also have the same issue you can change the oil something ek el but it will not guaranty the problem, just do a top up regulary.
    Btw tinry ko hindi mag top up, it averages 1-2ltrs ang kulang after 5t kms
    Quote Originally Posted by akosidags View Post
    What the mechanic is saying lang is that not as tough yung makina ng LC200 compared to 80/100 series. Hindi naman kailangan i-overhaul yan basta basta.
    Medyo malakas ang 1-2ltrs per 5K ah.
    The ones in the Middle East were subject to extreme conditions and the culprit was also the drivers who would overrev the engines.
    Aug 2005
    Ano lc mo local?
    May 2007
    Quote Originally Posted by imperialv View Post
    Ano lc mo local?
    Dubai gxr po
    Aug 2005
    Dubai din sa amin... I was wondering if pati yung local affected neto..
    Dubai gxr po
    May 2007
    Yes but read your owners manual it says its normal
    Aug 2005
    Will it solve if we install an oil catch?
    Oil catch can will only catch the oil. If you google LC200 lemon, yan lahat complaint ng mga tao hehe
    Pangit pala LC200
    Signature
    May 2007
    Pangit pala LC200
    Oo nga masaganda pa jimny solid axle pa
    ^Any service bulletins coming out on that?
    Pangit pala LC200
    Troll! Troll! Ban! Ban!
    Aug 2005
    I just need to know what is normal or not. Read somewhere that there was a faulty fuel pump that needed to be replaced.
    At least i know 1-2 liters per 5000 km is normal.
    Aug 2005
    I just need to know what is normal or not. I read that the cause for excessive oil consumption was a faulty fuel pump.
LC200 oil consumption?
