Hi guys,
How is the OIL CONSUMPTION of your LC? Sa amin, you need to top up everytime we had a long run.
Kamusta yung mga bago?
Hi guys,
I read about that oil consumption problem before.
But i don't have a LC200 so i can't confirm. :D
Nabasa ko sa 4x4ph na problem nga daw ng LC200 yung kumakain ng langis. Parang chief mechanic yata sa middle east yung nagpost. Several units na below 3 years old needed complete overhaul.
No need for overhaul not unless may problem talaga makina mo. You can read the lc200's manual na its normal yun ganyan not just for the 200 but also for fortuner. You need to top up talaga on the 200.
I cant recall which australian forum i read they also have the same issue you can change the oil something ek el but it will not guaranty the problem, just do a top up regulary.
Btw tinry ko hindi mag top up, it averages 1-2ltrs ang kulang after 5t kms
Oil catch can will only catch the oil. If you google LC200 lemon, yan lahat complaint ng mga tao hehe
I just need to know what is normal or not. Read somewhere that there was a faulty fuel pump that needed to be replaced.
At least i know 1-2 liters per 5000 km is normal.
I just need to know what is normal or not. I read that the cause for excessive oil consumption was a faulty fuel pump.
