Results 1 to 8 of 8
    Nov 2012
    Pa help naman ksi may konting prob. ako sa corolla bigbody XL ko..
    Pag dindrive ko tpos tinatapakan ko yung gas ng mjo madiin, sample nsa SLEX ako tpos xempre paaabutiin ko ng 100kph, pra mabilis, pag exit ko and nag slowdown na ako yung makina parang mamatay, tpos pag di ko na ginasan,... ayun mamatay na xa, guys what do you think about is the problem?
    Thx!!
    Jan 2013
    check your fuel filter baka barado or clean your carburetor baka madumi lang.
    Aug 2010
    have your carburaetor be clean or overhaul if possible, and palitan mo na rin anything related sa fuel system like fuel filter and also don't forget to check yung fuel pump, mechanical type kasi yan..baka tangos na yung groove kaya ganyan.
    Jan 2012
    sa madaling salita palyado yan, Tune-up ang kailangan makikita naman during tune-up kung my parts na dapat ng palitan or linisin....
    possible reasons:
    - spark plug needs replacement
    - dirty fuel filter
    - wala sa timing
    - dirty or busted carb
    - dirty air filter
    Jan 2019
    Mga sir,
    need help po. need ideas how to fix overheating engine ng toyota corolla xl bigbody pag nasa traffic lang po ano po possible repairs, parts na need icheck/palitan magkano po kaya lahat magagastos? may idea po ba kayo san best na shop dito banda sta rosa laguna?
    Thanks sa help.
    Jul 2013
    Quote Originally Posted by jmentos View Post
    Mga sir,
    Thanks sa help.
    hmmm... nag overheat na ba?
    If yes, you need to change the cylinder head gasket.
    Apr 2014
    Mga sir,
    Thanks sa help.
    Check the fan kung nag eengage pa. If not, dont go with the bypass always on mode like most mekanikos would suggest. Have the fan checked muna.
    Check rad kung may leak (including hoses).
    If naubos na ang coolant kahit kalalagay pa lang, check the water pump.
    At least yan ang makikita mo kaagad without even going to mekanikos sa tabi tabi.
Inquiries lang sa corolla bigbody XL
