Results 1 to 8 of 8
- Nov 2012
- 3
November 6th, 2012 08:26 PM #1Pa help naman ksi may konting prob. ako sa corolla bigbody XL ko..
Pag dindrive ko tpos tinatapakan ko yung gas ng mjo madiin, sample nsa SLEX ako tpos xempre paaabutiin ko ng 100kph, pra mabilis, pag exit ko and nag slowdown na ako yung makina parang mamatay, tpos pag di ko na ginasan,... ayun mamatay na xa, guys what do you think about is the problem?
Thx!!
- Jan 2013
- 6
February 2nd, 2013 07:02 PM #2check your fuel filter baka barado or clean your carburetor baka madumi lang.
February 4th, 2013 12:26 PM #3
have your carburaetor be clean or overhaul if possible, and palitan mo na rin anything related sa fuel system like fuel filter and also don't forget to check yung fuel pump, mechanical type kasi yan..baka tangos na yung groove kaya ganyan.
- Jan 2012
- 97
February 6th, 2013 01:24 PM #4sa madaling salita palyado yan, Tune-up ang kailangan makikita naman during tune-up kung my parts na dapat ng palitan or linisin....
February 6th, 2013 02:41 PM #5
possible reasons:
- spark plug needs replacement
- dirty fuel filter
- wala sa timing
- dirty or busted carb
- dirty air filter
- Jan 2019
- 2
January 22nd, 2019 05:17 PM #6Mga sir,
need help po. need ideas how to fix overheating engine ng toyota corolla xl bigbody pag nasa traffic lang po ano po possible repairs, parts na need icheck/palitan magkano po kaya lahat magagastos? may idea po ba kayo san best na shop dito banda sta rosa laguna?
Thanks sa help.
January 22nd, 2019 06:51 PM #7
January 22nd, 2019 06:58 PM #8
Check the fan kung nag eengage pa. If not, dont go with the bypass always on mode like most mekanikos would suggest. Have the fan checked muna.
Check rad kung may leak (including hoses).
If naubos na ang coolant kahit kalalagay pa lang, check the water pump.
At least yan ang makikita mo kaagad without even going to mekanikos sa tabi tabi.
Latest mileage:
