[SIZE=3]Good day mga ka-Innova,[/SIZE]
[SIZE=3]Share ko lang po yung ilan sa modification na ginawa ko sa Innova.[/SIZE]
[SIZE=3]Shift Knob Cover - leather material, retaso sa BMW leathers, had some hard time cutting & sewing but its all worth the effort. Stock shift knob lang po na binalutan.[/SIZE]
[SIZE=3]Key Alarm Cover - same leather material, natira sa ginamit ko sa shift knob, just to protect the key alarm from scratches & "bugbog".. medyo di clear sa pics, pero maganda sya sa actual at kakaiba....[/SIZE]
[SIZE=3]Medyo kailangan lang kabisado yung buttons, anyway madali lang dahil 3 lang naman yung sa Innova G.[/SIZE]
[SIZE=3]Drive safe & always extend patience on the road...[/SIZE]
[SIZE=3]Aldz[/SIZE]
mga sir tanong ko lang, i got my innova last weekend lang, innova G matic.
Im planning to put rear spoiler (without LED), front, side and rear skirts and sill plate sa interior.
Please note i wanted OEM design copy and sana plastic. pero kung halos presyong casa yung plastic ill go with fiber glass na lang.
pa PM na lang mga shop owners. planning to do it this coming weekend.
TIA
Mga bro, back read lang kayo nasagot na ito.Originally Posted by D4D AT808 View Post
meron po ba kayo alam na magandang floor mat yung sukat talaga sa innova. preferrably plastic or rbber type. any brand you may suggest and if you got pics. pls. Thanks!
D4D AT808.
beige metallic.
custom made ang hanap nyo, so you better visit Lederland sa West Ave. near Cabalen for materials and fit of your choice, you can also see actual fitting on Jerry's Innova always parked in front of the shop. (Jerry is the owner of Lederland).
Else, you can also back read here on how to make your own DIY floor mat using per meter coiled mat from HandyMan or ACE like I did. You can also back read to see the picture of my Lederland custom seat cover and DIY floor mat.
Lederland ba also customized synth leather for other car models like mitsu adventure?
Can the Innova E side mirrors be converted to powered? If so, how much?
Mga sir's, please help i'm planning to change my innova j HEAD UNIT. I need sana ung diagram/pin assignments/color coding and kung merong male connector para dina ko mag wire splicing.
Thanks.
To : alvin_alvin,
I just had my Head Unit (H.U.) upgrade and used the stock terminals ng Innova, so far ok na ok naman since, mga more than 3 months na din. Female terminals ksi yung sa terminal ng innova radio so nag solder ako ng male terminals (small type) sa new H.U. then wrap it with shrinkable insulation then direct plug na sa terminals ng stock wiring at presto!!! Walang modification at ok na ok, bundled the wires with cable tie after connecting to make it neat at di madali makalas.
Here are the coding:
BIG SOCKET SET
green with gray = + front right speaker
blue with gray = - front right speaker
pink with gray = + front left speaker
volet with gray = - front left speaker
brown with gray = fixed body ground
black = remote antenna
green = parklite
gray = accessory
blue with yellow stripe = fixed battery positive(mas mataba ito kumpara sa ibang wires na katabi nya)
SMALL SOCKET SET
black with gray = + rear left speaker
yellow with gray = - rear left speaker
red with gray = + rear right speaker
white with gray = - rear right speaker
Hope this helps... goodluck on your project
hi guys, na post ko na po sa other thread this question, but it seems appropriate in this thread, query ko po.. is it possible to have a montero side step installed at my innova... just a thought lang po gandahan po kasi ako sa sidestep ng monty.and if ever its possible does anybody knows how much is the cost..
Hi mga sir,
San ko ba pwede ipagawa ung side mouldings ng innova ko? kasi natatanggal na ung mga dulo.
or better, what can i use para madikit ko ung mouldings ko.. mighty bond?
saka ung price ba na 1,500 for the mudguard is per piece or 4 na un?
HTH
