Results 1 to 20 of 30
    Jul 2003
    Aluminum ba yun Radiator ng Super Grandia 2008? Bakit may leak pag malamig yung makina pero kung umaandar wala naman...
    Apr 2008
    Quote Originally Posted by acenie View Post
    Probably because the leak is not very big... And the water simply evaporates when the engine is hot.
    Sent from my SM-G900I using Tapatalk
    Jul 2003
    Quote Originally Posted by gti View Post
    probably because the leak is not very big... And the water simply evaporates when the engine is hot.
    Sent from my sm-g900i using tapatalk
    pwede pa ba ma repair? Kayaba sa mga radiator shop? Sir?
    Mahinang bayan aluminum? Hindi plastik yung cover? Parang aluminum?
    Oct 2009
    yes meron na ngayon naghihinang ng aluminum.pero hindi lahat ng radiator shop meron nun..pwede ka rin mag tanong sa mga machine shop kung meron silang pang aluminum.para pa baklas mo nalang at ikaw nalang mismo magdala sa machine shop
    that doesn't sound like a real leak.
    can you describe it, po? location?
    na-uubusan ba kayo ng coolant?
    Jul 2003
    pag umaga meron ng tubig sa baba (coolant) red color tapos tinignan ko yung coolant reservior may kulang... sinilip ko sa nakita ko sa may radiator galing parang sa bandang taas ng cover nya sa baba. aluminum hindi naman plastic yung cover
    bro makikita mo yan parang powdery yung coolant sa source ng leak.
    Jul 2003
    hindi lang powdery sir pag umaga may tumutulo na coolant sa baba nakita ko doon mismo sa pinaka part na mga rows ng radiator sa may cover sa baba
    bro sobrang di halata yan leaks na yan while running or after long cool down. kumbaga sakto moment mo sya makikita, i guess within 30 minutes to an hour after engine is Off.
    from a 30 minute drive ko nakita yun spots.
    eto naman mga leak spots na nakita ko, kaya ko binaklas yun rad.
    eto naman vid nung malakas na leak, even * idle ..
    tiny leak 2 - YouTube
    Aug 2017
    Has anyone tried radiator stop leak products in cases like this? How was it?
    my wild guess, is your radiator cover needs replacement.
    Mar 2004
    Make sure to replace it with proper spec cover ... There are different types depending on pressure ...
    Jul 2003
    sir ang nakikita kong leak e doon mismo sa baba ng mga rows sa may cover ng radiator sa baba part nya
    it probably gravitated towards the lower parts, from above.
    you'll just have to see where it is coming from.
    use a strong light source.
    Jun 2015
    try mo evercool radiator sir
Hiace Super Grandia 2008 Radiator water Leak..
