Results 1 to 20 of 30
    Quote Originally Posted by acenie View Post
    Aluminum ba yun Radiator ng Super Grandia 2008? Bakit may leak pag malamig yung makina pero kung umaandar wala naman...
    that doesn't sound like a real leak.
    can you describe it, po? location?
    na-uubusan ba kayo ng coolant?
    Jul 2003
    pag umaga meron ng tubig sa baba (coolant) red color tapos tinignan ko yung coolant reservior may kulang... sinilip ko sa nakita ko sa may radiator galing parang sa bandang taas ng cover nya sa baba. aluminum hindi naman plastic yung cover
    bro makikita mo yan parang powdery yung coolant sa source ng leak.
    Jul 2003
    hindi lang powdery sir pag umaga may tumutulo na coolant sa baba nakita ko doon mismo sa pinaka part na mga rows ng radiator sa may cover sa baba
    bro sobrang di halata yan leaks na yan while running or after long cool down. kumbaga sakto moment mo sya makikita, i guess within 30 minutes to an hour after engine is Off.
    from a 30 minute drive ko nakita yun spots.
    eto naman mga leak spots na nakita ko, kaya ko binaklas yun rad.
    eto naman vid nung malakas na leak, even * idle ..
    tiny leak 2 - YouTube
    Aug 2017
    Has anyone tried radiator stop leak products in cases like this? How was it?
    Apr 2010
    Quote Originally Posted by SidCoronel View Post
    Not me but a friend did. It blocked radiator passages when it was opened
    Also do not replace an aluminium/plastic cover with a brass one ("tanso") = galvanic corrosion. i mean it can give you months or years of trouble-free operation but is not the best way to go.
    Aug 2017
    Quote Originally Posted by ParticleX View Post
    Interesting, thanks.
    After how many months after was the radiator opened up?
    Jul 2003
    bumili na ako ng bago radiator. ok lang ba na yung plastic cover na ang ipalit ko kasi yung dati aluminum?
    my wild guess, is your radiator cover needs replacement.
    Mar 2004
    Make sure to replace it with proper spec cover ... There are different types depending on pressure ...
    Jul 2003
    sir ang nakikita kong leak e doon mismo sa baba ng mga rows sa may cover ng radiator sa baba part nya
    it probably gravitated towards the lower parts, from above.
    you'll just have to see where it is coming from.
    use a strong light source.
    Jul 2003
    ok sir i will check it again, pero sinabi ko na sa mekaniko ko na alisin nalang yung radiator para ma check
Hiace Super Grandia 2008 Radiator water Leak..
