Mga Guru's Help naman po. I'd like to make a follow up sana sa thread na ginawa ko about the ignition coil. Recently I changed my ignition coil and its ballast resistor on a Corolla XL 91 with a 2E engine. The catch is, when we started the car it sounded fine. unfortunatley, biglang umusok yun external ballast resistor (it came with the ignition coil when i bought it; a hitachi ignition coil). When we took it out, it was smoking hot. So my mechanic decided to use the old ballast resistor nalang. S akin okei lang pero I would prefer na bago na din yun resistor. The value of the resistor, as stamped on it is 1.6 OHMS. My question po dear guru's, do you have any idea ano ang value ng stock resistor ng isang 2E engine. We could'nt read the OHM rating in the old ballast kasi maitim na sa tagal nya (my mechanic guessed it is still the original stock pa) kaya i'd like to change it also, 20 years na din yun. Help lang po what value should I buy na compatible....if I buy a lower value ok lang ba or should I buy a higher value...Any input will be very much appreciated!
A follow-up question....could it be mga guru's kaya umuusok dahil natutunaw lang yun coating nun coil sa loob ng ballast dahil bago????? Kindly correct me nalang po thanks and more power to the forum!
Kayo po sir?....Those where my days kasi when we tinkered electronic/electrical stuff...tsaka yun mga theories etc.
