Results 1 to 9 of 9
- Oct 2012
- 4
October 19th, 2012 05:13 PM #1Good Day po sa inyo.
May Toyota Corolla Big Body po ako. Nanotice ko po kc may unusual vibrating siya especially pagnaka-idle po with the aircon on. When I turn on the car po, it vibrates na plus with the aircon, lalo siya nanginginig talaga. May Big Body din po un bro-in-law ko and I noticed yung sa kanya hindi naman ganun magvibrate. Nagpacheck po ako, sabi nila baka engine support daw po. Nakapagpa-change oil and other fluids na po ako. Hindi ko po alam kung yan lang yung problema sa kotse ko.
Eto po mga tanong ko:
1. MAy magandang brand po ba na engine support or OEM?
2. May idea po ba kayo how much ang engine support?
2. Im located in QC po, where can I find a trusted shop to get the engine support and also, saan po ako makapag-install nito?
3. What's a good and trusted shop po for engine, underchassis, shocks and suspension problems?
Thank you po for the time to read and answer my questions.
October 19th, 2012 05:22 PM #2
I think Toyorama has engine supports. They're in Banawe. No idea sa price. You can decide don what fits your budget. For a set of 4 na replacement siguro mga 3k total. Origs mas mahal of course.
The big body is common enough that most auto supply shops stock parts for it. Try asking dyan sa inyo. Then compare prices with Toyorama. Baka di na bale dumayo pa for the price diff.
Any decent mechanic can change engine supports. Since you sound like a newbie I won't advice bringing your car to Banawe. Madami nabibiktima dyan kung di mo alam what to watch out forLast edited by JohnM; October 19th, 2012 at 05:27 PM.
October 19th, 2012 05:30 PM #3
+1 sa toyorama
Gusto mo bago ka pumunta tawagan mo muna sila : 7120016
At tama si johnM, madami pakulo dyan sa banawe at mas mabuti pa mag commute ka na lang papunta dun, or iwan mo sa parking ng puregold yung auto mo
October 19th, 2012 05:32 PM #4
Pwede din pala M7: Branches, Franchise and Authorized Dealers - M7 Enterprises
They refurbish engine supports pero AFAIK they use truck tires and they're not as soft and comfy as the replacements let alone OEMs. Pero walang tatalo sa tibayLast edited by JohnM; October 19th, 2012 at 05:35 PM.
- Oct 2012
- 4
October 20th, 2012 12:56 AM #5
- Oct 2012
- 4
October 20th, 2012 01:47 AM #6
October 23rd, 2012 12:56 AM #7
How do you know kung ang engine support ang may problema?
Sent from my iPad using Tapatalk HD
November 6th, 2012 11:33 PM #9
Mga Sir, any idea how much un Engine Supports?
thanks.
high idle RPM at engine start
