Results 1 to 20 of 29
    Apr 2008
    help please.. after ive installed NARVA WIRING HARNESS 130/90 for headlamps.. whenever i switch on to high beams, the low beams will still be on.. ive already crack 2 h4bulbs.. please i need help.. what should i do? my car is a toyota lovelife (LE 2000model)...
    May 2007
    You have to rewire it again. Follow the instructions properly, aftermarket wiring are diff. into your oem.
    Apr 2008
    Apr 2008
    wats a OEM sir? ive search the web and found some topics thats similar to mine.. i tried rewiring it.. tried diferent variations but still no good.
    May 2007
    Quote Originally Posted by mrkoolk View Post
    Original Equipment Marerial (OEM). Did you have instruction w/ you?
    Apr 2008
    Quote Originally Posted by v6dreamer View Post
    none sir.. i just bought it from ace hardware.. my friend uses the same thing and it works just right
    May 2007
    your best bet is to look at your friend's car how did he do. Your car and his may have diff., color on wiring unless both of you have the same car. To do this is connect the same configuration on his, high to high, low to low. Disregard the color coding on the wiring since your main concern is to make it work properly.
    Jan 2003
    sir, correct me if im wrong but, i think OEM stands for Original Equipment Manufacturer.Peace
    ^^^ That is correct the correct definition :thumbup:
    *mrkoolk - sabay ba? eh di nabigla ka at first talo mo pa HIDs
    Sep 2004
    if you cant fix it, have an electrician looked into it. Baka napagbaliktad mo lang ang positive and negative ng isa sa mga contacts.
    Apr 2008
    sir albert.. ocge po.. thankyou.. nice car..
    Sep 2004
    Same problem here to my Mazda Tribute. Already sent to casa but di rin naayos ng mga electricians nila.
    Apr 2008
    Quote Originally Posted by comecum View Post
    sir i nid help.. i tried different kinds of variations on wire wire connections but still cant fix it.. badtrip.. diko alam kung san hahanap ng sagot..
HELP!!both high and low beams work at the same time after i instled narva hanesswire?
