Results 1 to 10 of 29
April 23rd, 2008 11:39 PM #1
help please.. after ive installed NARVA WIRING HARNESS 130/90 for headlamps.. whenever i switch on to high beams, the low beams will still be on.. ive already crack 2 h4bulbs.. please i need help.. what should i do? my car is a toyota lovelife (LE 2000model)...
April 24th, 2008 12:02 AM #2
You have to rewire it again. Follow the instructions properly, aftermarket wiring are diff. into your oem.
April 24th, 2008 12:06 AM #3
April 24th, 2008 12:10 AM #4
if you cant fix it, have an electrician looked into it. Baka napagbaliktad mo lang ang positive and negative ng isa sa mga contacts.
April 24th, 2008 12:10 AM #5
wats a OEM sir? ive search the web and found some topics thats similar to mine.. i tried rewiring it.. tried diferent variations but still no good.
April 24th, 2008 12:14 AM #7
April 24th, 2008 12:22 AM #8
April 24th, 2008 12:35 AM #9
your best bet is to look at your friend's car how did he do. Your car and his may have diff., color on wiring unless both of you have the same car. To do this is connect the same configuration on his, high to high, low to low. Disregard the color coding on the wiring since your main concern is to make it work properly.
April 24th, 2008 12:43 AM #10
Traffic!
