Results 1 to 4 of 4
- Aug 2009
- 2
August 22nd, 2009 01:22 PM #1guys need help naman. nagbaha sa amin, tapos napasukan ng baha ang loob ng kotse, nabasa ang floor matting, pero hindi naman umabot sa upuan hanggang matting lang. anu kayang magandang gawin sa vios ko?
tnx in advance guys and drive safely.
August 22nd, 2009 01:26 PM #2
take the carpet off then sun dry
or park your car under the sun then leave the windows open
August 22nd, 2009 01:37 PM #3
Not really hard, but VERY involved...
You have to remove the seats, front and back, take off all "kick" panels from the door jams (the ones that screw to the lower edge, the carpet goes under them), the kick panels under the dash (both sides), the center console, and maybe way up under the dash (on the front edge of the carpet) there may be a couple trim strips there too...
You can also consider buying a small wet and dry vacuum, and vacuum carefully all the moisture that is under there...that takes much longer, as you have to do it a lot of times to finally get ALL the moisture out...hair dryers also help, once you got the majority sucked out through the carpet.
Wheeew! make sure you have a lot of an ice cold beer while doing it.
August 22nd, 2009 01:48 PM #4
yep you have to take the carpet off , then sun dry. or, you could remove the cellophane (if you have one) then open the doors of your car to let it sun dry. of course, the seats must be removed, and the other panels that covers the upholstery. it's a very strainous job. better if you get someone to help you. you can also put an electric fan inside the car (using extension cord) though mas ok cguro ang hair dryer kasi hot air.
