Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Dec 2009
    Sometimes the gas pedal of my corolla altis get stuck so I need to press harder to depress the pedal. I think the gas pedal is worn out so I wanted it to be checked and fixed. I would like to ask your advice whether it's best to bring my car to Toyota casa or any other autoshop can handle it?
    Normally if that happens, the linkage needs lubrication or the cable needs replacing.
    Jan 2009
    Toyota + Stuck Accelerator Pedal. Isn't this the subject of the recent massive Toyota recall?
    ^ Yeah. My sentiments exactly. Pero what model year of the altis kaya yung kay TS ?
    Dec 2009
    Mine is 2003 so not sure if related to the "Recall" thread. Actually I asked the question there but didn't get a response.
    Dec 2009
    Thanks ghosthunter. Is this something that can be entrusted to any auto technician? How about the part, is it okay to use replacement or should I go for the original?
    ^ 2003 pala. Di pa kasama yan.
    Quote Originally Posted by samcoy View Post
    Any competent auto tech will be able to do this. Depending on the cause of the problem, but I would prefer to get original part on this if possible.
    You might want to check why the pedal gets stuck... like rust or dirt found in the linkage/cable would mean its not normal a wear & tear issue.
    Possible recent flooding could have washed away grease or lubricating oil or deposited mud/dirt into the linkage/cable.
    Sep 2006
    its a mechanical defect that can be remedied.
    goto:
    http://en.wikipedia.org/wiki/2010_Toyota_vehicle_recall
    Dec 2009
    Thanks again.
    your throtle cannot move freely because of carbon deposits. remove your air intake tube & clean your throtle using wd40. this is just a simple DIY.
    Or used a Carb Cleaner...
    [SIZE="4"]Correction:
    Using WD40 or Carb Cleaner can damage your TB FIAV.
    http://www.3si.org/wiki/index.php/FIAV
    [/SIZE]
    Baka naman talagang kasama yung modelong to sa fiasco?
    It get stuck ba pag binitawan mo? pero pag nakadagan ka lagi sa pedal d naman nag stuck?
    kung ito iyon, nangyari na sa amin ito sa lancer.
    you have to kick the pedal to get out of the "Stuck area" kaya that time hindi ko binibitawan ang gas pedal, kasi once binitawan ko at bumalik sa taas, matigas na apakan.
    I check under the hood at ang nakita ko is maluwag na yung turnilyo ( almost malalaglag na) sa gas pedal na nag aalis ng slack sa cable. maliit na turnilyo lang siya. dapat kasi iyong cable batak ng konti
    you can find the turnilyo under the hood, malapit iyan duon sa part na pinipindot ng mekaniko para magrevolution yung auto, macheck mo din dito kung stuck nga cable mo
    Jul 2006
    ganyan din ngayon ang 97 rav4 ko. na-stuck stuck. Ginawa ko na yang carb cleaner, wd40 at grease pero ganun pa rin. Papalitan ng cable ang solution pero mukhang mahal yata yung cable.
    kasi yung cabl e naman, d naman ganoon kadali masira iyan, kahit bahain yan or magkalikabok sa loob, alam ko design yan to resist elements.
    kung masisilip nyo maigi yung butterfly throtle yun ang nag cause kung bakit parang naninikit or parang matigas ang accelerator pedal. yung mga gilid nun napupuno ng carbon deposits. linisin nyo lang yun ng maayos. yung cable hindi basta basta nasisira yan or naiipit. di na kelangan kalasin lahat yung tube lang ng air filter para ma-access mo yung throtle.
    yung sa ae101 ko ganyan lang ginawa ko nilinis ko lang ng wd40 at toothbrush saka basahan problem solved.
    kung nanonood kayo ng news walang toyota cars na nirecall sa pinas unless import ang auto nyo from US.
    Oct 2009
    naku pa check agad para sure walang kaso yan
Gas pedal sometimes get stuck
