Results 11 to 20 of 27
- Mar 2009
- 25
February 8th, 2010 12:41 PM #11your throtle cannot move freely because of carbon deposits. remove your air intake tube & clean your throtle using wd40. this is just a simple DIY.
February 9th, 2010 01:38 AM #14
[SIZE="4"]Correction:
Using WD40 or Carb Cleaner can damage your TB FIAV.
http://www.3si.org/wiki/index.php/FIAV[/SIZE]
Tsikot Member Rank 4
- 1,842
February 9th, 2010 01:58 AM #16
It get stuck ba pag binitawan mo? pero pag nakadagan ka lagi sa pedal d naman nag stuck?
kung ito iyon, nangyari na sa amin ito sa lancer.
you have to kick the pedal to get out of the "Stuck area" kaya that time hindi ko binibitawan ang gas pedal, kasi once binitawan ko at bumalik sa taas, matigas na apakan.
I check under the hood at ang nakita ko is maluwag na yung turnilyo ( almost malalaglag na) sa gas pedal na nag aalis ng slack sa cable. maliit na turnilyo lang siya. dapat kasi iyong cable batak ng konti
you can find the turnilyo under the hood, malapit iyan duon sa part na pinipindot ng mekaniko para magrevolution yung auto, macheck mo din dito kung stuck nga cable moLast edited by MAXBUWAYA; February 9th, 2010 at 02:03 AM.
February 9th, 2010 02:02 AM #17
ganyan din ngayon ang 97 rav4 ko. na-stuck stuck. Ginawa ko na yang carb cleaner, wd40 at grease pero ganun pa rin. Papalitan ng cable ang solution pero mukhang mahal yata yung cable.
- 1,842
February 9th, 2010 02:06 AM #18kasi yung cabl e naman, d naman ganoon kadali masira iyan, kahit bahain yan or magkalikabok sa loob, alam ko design yan to resist elements.
- Mar 2009
- 25
February 9th, 2010 05:21 PM #19kung masisilip nyo maigi yung butterfly throtle yun ang nag cause kung bakit parang naninikit or parang matigas ang accelerator pedal. yung mga gilid nun napupuno ng carbon deposits. linisin nyo lang yun ng maayos. yung cable hindi basta basta nasisira yan or naiipit. di na kelangan kalasin lahat yung tube lang ng air filter para ma-access mo yung throtle.
yung sa ae101 ko ganyan lang ginawa ko nilinis ko lang ng wd40 at toothbrush saka basahan problem solved.
kung nanonood kayo ng news walang toyota cars na nirecall sa pinas unless import ang auto nyo from US.
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
