how do we improve or soften the ride of the toyota f4x4 fortuner? whats the best way?![]()
short term solution and probably the cheapest way is to decrease the recommended tire pressure by around 4 to 5 lbs/sq in. however, you might have to sacrifice the life span of your tire...
maybe the best method is to replace the existing shocks, i know some people who were pretty satisfied with the ride right after changing the shocks
you may also try to visit and learn from the fortuner owners on this site.
http://pinoyfortuner.14.forumer.com/index.php
I wouldn't lower the tire pressure THAT much. Delikado din kasi sa blow-out eh dahil baka me-deform ang belts. There are ads for aftermarket springs but I haven't tried them myself.
Seriously though. Ride comfort is one of the things that should be tested in the test drive.
Doon sa hindi pa nakaka-try, kung gusto niyo talaga nice ride, try the FXT. Grabe. Palagay ko next down will be the SF.
use nitrogen on your tires, get an aftermarket set of springs and shocks.
try speedlab spring and shocks combo
bilstein shocks
H&R springs
here's the link:
http://www.speedlab.com.ph/installat...ilsteinh&r.htm
Test drove the Forester XT once, and was surprised how extremely comfortable it is and without compromising handling. Mas maganda ride nya kaysa bagong accord.
To improve your fort's ride significantly I think you should fit it with air bag suspension. Kaya nga lang it's expensive and dont know if kits are made for fortuners.
Simple. Add ballast to the rear of the vehicle.
The suspension is designed to carry heavy loads. So if the vehicle is unloaded, the ride will be jarring or stiff. Adding a few kilos of ballast will soften the ride.
Your options for ballast would be:
-sacks of rice
-sacks of sand
-sacks of cat litter
-anything else that weighs a lot but cheap to buy and would stay put in the back.
try nyo po mag log in sa fortuner club dami threads dun concerning ur quiry...![]()
