Page 4 of 7 FirstFirst 1234567 LastLast
Results 61 to 80 of 139
    Oct 2005
    sir vic, quick question lang, had the same turbo timer you have installed, problem lang pag nakaactivate na, umiilaw yung abs warning light ko( d ko napansin nung pinainstall ko). pag di ko naman ginamit yung timer d naman lumalabas. na experience mo na ba 'to?
    Mar 2005
    Quote Originally Posted by sean jedi
    I'm just having my turbo timer installed. Nakakabit na actually. But, a wire tapping to the alarm ON hasn't been connected. The timer already counts down but it doesn't leave the enigine running pa. My unit is now in the casa for the final wire-tap. I haven't noticed that the ABS light switches on. Pa-check mo sa nag-install ang timer mo. One possibility is that he may have tapped to a wrong wire.
    Update kita once I get my unit later.
    Mar 2005
    Quote Originally Posted by vicoyski
    Just got my unit. The ABS light does come on when the timer counts down to shut-off. It's a reminder daw so that you will engage your handbrake and shift the stick to Park. Else, your unit might roll until it hits something (or someone) as the turbo timer counts down to shut-off.
    I really like the audible countdown beeps. I'll post pics later...
    Oct 2005
    Good to hear na ganun talaga pala. i thought may problem sakin. I'll be using it again. I stopped using it kasi when i saw the abs light up. problem na lang are the stares i get from people when they see me arm the alarm and leave the engine running... BTW, did you get to install the orange wire?
    Mar 2005
    Yup! All wires got installed daw... Why'd you ask?
    star sensor??
    Sep 2005
    Vicoyski: ask o lang how much you paid for the turbo timer and how long will they install it? tia...
    Mar 2005
    Quote Originally Posted by JunDC
    Got the Turbo Timer from Miggyboy Accessories for less than P2T. Had it installed free at the dealership, thanks to my kind SA! Installation will take less than a day.
    turbo timer ba pwede sa gas ?
    Sep 2004
    pwede if your ride has turbo.
    May 2005
    And since the Fortuner 2.7 vvti has no turbo therefore the timer is not needed. :D
    Has anyone tried these from Ziebart?
    1) Diamond Gloss
    2) Undercoat Sound Barrier
    How much will these cost and how long does it take for both applications?
    Does the Undercoat sound barrier really improve sound dampenning? Does it protect against rust? Or shall I have a separate rust proofing applied?
    Thanks for your inputs....
    Sep 2005
    Had mine DG, Php8,200.00.
    Sep 2004
    1) Diamond Gloss
    regarding diamond gloss, may nakausap akong fortuner owner na masyado daw manipis ang coat ng paint ng fortuner a staff from ziebart told her daw after her unit undergone diamond gloss treatment.
    Quote Originally Posted by bilog
    bilog,
    does this mean ninipis ang paint coating bago i-apply ang Dimond Gloss? Or talagang manipis na ang coating before application?
    attynorby
    "Had mine DG, Php8,200.00. "
    attynorby, any comments po tunkol dito sa sinabi ni bilog? Will DG prevent minor scratches (say from plants, etc.)? Nilagyan din ba ang loob (inner side)ng mga pinto and arches?
    Anybody: on the Underbody Sound Barrier from Ziebart? Thanks sa mga comments and suggestions....
    May 2004
    mga bro, may nagpakabit na ba ng roof rack sa inyo? malamang kailanganin ko eh. anong klase/brand pinakabit nyo? ok/bagay ba? TIA
    Aug 2005
    Quote Originally Posted by konde
    nagpalagay me pero bihira ko rin nagagamit , aerorack brand 3,500 lang sa goldrich banawe, may carryboy din pero mahal nasa 6,000-8,000 ata and parang mas konti bakal yun sa carryboy, after installing kailangan ka pa kumuha ng permit sa LTO yan, tawag nila TOP LOAD, minimal fees lang, ang disadvantage lang sa roofrack ko (dunno with other brand) is when you reach the speed between 120-130kph,may vibration kang maririnig galing sa roof :down: nakakapagtaka nga eh kc pag over 130kph mawawala yun vibration, basta may vibration lang bet 120-130kph
    bumili ako ng car cover for SUV hirap kasi mag linis ng roof. cover ko nalang sya. cost me 2000 for that. ok naman fit na fit sa fortuner.
    May 2004
    Quote Originally Posted by letranboy
    san ka sir nakabili? di ba nakakagasgas?TIA
    May 2005
    Best bet for a car cover is an all weather one, medyo mahal but at least you can use it any where not like the others which are like paper (only used indoors) and degrades in time.
    Mostly available in all Car accessories shops and Hardware shops sa malls.
Fortuner Accessories
