Page 3 of 7 FirstFirst 1234567 LastLast
Results 41 to 60 of 139
    Aug 2005
    Quote Originally Posted by bigfellow2k
    sino po sainyo nagpakabit ng front sensor?
    me, bale 6 sensor (2front 4 rear) 4,500 sa goldcar banawe including installation, indicator niya sa rear view mirror
    one of our entry in the recent Robinsons Place Bacolod Motor Show. Sound set-up by Centerline. Mags and tires by MA Wheel Options.
    Sep 2005
    para sa akin sulit yung hid lights, lalo na naka tint yung buong windshield ko ng black, laking tulong ng hid sa vision ko pag gabi.
    Jan 2003
    Quote Originally Posted by RGM
    sir malaking tulong nga yan sa vision mo, but how about yung vision ng kasalubong mo?
    Sep 2005
    Quote Originally Posted by hector angel
    Sobrang nakaksilaw ba sa mga kasalubong? Kahit noon pa kasi laging full tint ang windshield ko kaya pag may kasalubong ako na naka HID rin di ako apektado. Dapat pala ipagbawal na HID lights kung hazardous ito sa mga motorists.
    HID lights should only be equipped on projector-type headlamps.
    AFAIK - hindi projector-type ang nasa Fortuner.
    Aug 2005
    Here's one item on the legality of alternative headlights which read: Excessive light in some directions can dazzle other drivers. It is possible for you to be legally liable if this causes or contributes to an accident. Modified headlights might have insufficient light in some directions, and you could be held legally liable if that causes or contributes to an accident.
    source: http://members.misty.com/don/d2.html
    Jun 2005
    guys tanong lang. Hindi ba na vo-void ang warranty when you install front/backup sensors? How about sound setup?
    Meron ba kayo pics kung pano install (step-by-step) ang rear parking sensor? Pics din kung pano buksan ang rear side panels at kung saan pinadaan ang wiring papunta or galing sa reverse lights.
    Thanks...
    Mar 2005
    Quote Originally Posted by shockz
    Thanks...
    No need for pics actually... Just gently pull-off the rubber seal around the rear door on the side where you wanna tap to the reverse lights. You don't really need to pull-off the whole rubber seal. Just be careful not to mess up the upholstery with the rubber seal grease. Kad-kad mo lang yung wire along the edges of the side panels. It's really simple. You can fix the reverse sensor control unit in the jack stowbox. Use heavy duty (3M) double adhesive tape to fix it to the inside of the side panel.
    Quote Originally Posted by vicoyski
    Thanks Sir Vic. I will DIY hopefully before Xmas. Just bought my sensors eh.
    Merry Xmas na sa lahat :cheers::toma: ... baka maging busy na tayo at makalimutan na bumati....
    Sep 2004
    may nagpakabit na ba ng door sills para sa fortuner nyo? i am thinking of installing one.
    fortuner13,
    pano yung sa harapan na sensor? always on ba sya ? kasi nagtanong ako sa banawe, yung front sensor daw gagana lang pag naka reverse ka then me allowance ata around 5 seconds na naka on yung front, after patay na ulit, di kung ganon parang walang use yung front sensor
    Aug 2005
    bigfellow2k
    palagi gumagana front sensor kc minsan pag trapik tapos may tao na dadaan mismo sa front mo e gumagana yun indicator, pero pag shift mo yun gear sa Reverse automatic back sensor ang activated kc lalabas agad sa rear view mirror yun distance indicator, fyi may beep sound yun indicator niya pero pag naiingayan ka pwede mo rin off yun sound
    me naglagay na ba sainyo nung control sa manilbela just like the one on thailand fortuner models? is this available?
    fortuner13,
    anong brand ng sensor mo? san ka po nagpakabit? san nya kaya tap yung front sensor? direct sa battery kaya, baka mali yung tinanungan ko, kasi ano nga naman use ng front sensor pag naka reverse ka lang gagana, kakahilo yun ah
    Aug 2005
    bigfellow2K
    forgot ko na brand pero AFAIK made in taiwan lahat, sa goldcar (back of Dencio's grill) ako nagpakabit 4,500/set incuding installation bale 6sensor lahat (2front, 4 back)
    tap niya front sensor malapit sa fog light
    For the info of fortuner owners, OME shocks are now available for your rides.
    Nov 2003
    Quote Originally Posted by ARB
    Has anyone tried changing their shocks to OME? Balita ko P26,600 ang package. Definitely softer ride but actual experience would be helpfull. Any feedback please.
    Mar 2004
    Kita ko to sa parking. Anong klaseng sensor ba ito?
    closer
Fortuner Accessories
