Results 51 to 60 of 139
- Nov 2005
- 31
December 20th, 2005 07:18 PM #51fortuner13,
pano yung sa harapan na sensor? always on ba sya ? kasi nagtanong ako sa banawe, yung front sensor daw gagana lang pag naka reverse ka then me allowance ata around 5 seconds na naka on yung front, after patay na ulit, di kung ganon parang walang use yung front sensor
- Nov 2005
- 31
December 20th, 2005 10:44 PM #52me naglagay na ba sainyo nung control sa manilbela just like the one on thailand fortuner models? is this available?
December 20th, 2005 11:02 PM #53
bigfellow2k
palagi gumagana front sensor kc minsan pag trapik tapos may tao na dadaan mismo sa front mo e gumagana yun indicator, pero pag shift mo yun gear sa Reverse automatic back sensor ang activated kc lalabas agad sa rear view mirror yun distance indicator, fyi may beep sound yun indicator niya pero pag naiingayan ka pwede mo rin off yun sound
- Nov 2005
- 31
December 20th, 2005 11:07 PM #54fortuner13,
anong brand ng sensor mo? san ka po nagpakabit? san nya kaya tap yung front sensor? direct sa battery kaya, baka mali yung tinanungan ko, kasi ano nga naman use ng front sensor pag naka reverse ka lang gagana, kakahilo yun ah
December 20th, 2005 11:23 PM #55
bigfellow2K
forgot ko na brand pero AFAIK made in taiwan lahat, sa goldcar (back of Dencio's grill) ako nagpakabit 4,500/set incuding installation bale 6sensor lahat (2front, 4 back)
tap niya front sensor malapit sa fog light
December 21st, 2005 06:58 PM #56
For the info of fortuner owners, OME shocks are now available for your rides.
December 22nd, 2005 02:32 AM #57Originally Posted by vicoyski
Thanks Sir Vic. I will DIY hopefully before Xmas. Just bought my sensors eh.
Merry Xmas na sa lahat :cheers::toma: ... baka maging busy na tayo at makalimutan na bumati....
December 22nd, 2005 09:13 AM #58
guys tanong lang. Hindi ba na vo-void ang warranty when you install front/backup sensors? How about sound setup?
- Mar 2004
- 18
December 30th, 2005 10:11 AM #60
sir vic, quick question lang, had the same turbo timer you have installed, problem lang pag nakaactivate na, umiilaw yung abs warning light ko( d ko napansin nung pinainstall ko). pag di ko naman ginamit yung timer d naman lumalabas. na experience mo na ba 'to?
high idle RPM at engine start
