Results 1 to 4 of 4
    Jul 2010
    Ano po kaya problem ng car radio ko? Kapag nakikinig po ako ng fm staion tapos naka on ang aircon lumalabo ang yung fm station, parang static po yata. Lalo na po pag ginamit ko pa po yung cigarette lighter lalong lumalakas yung static nung radio ko po. Help naman po.
    Quote Originally Posted by devond View Post
    i'm not an electrician, so i'm shooting in the dark here...
    1. your static filter is out of whack. a radio repairman can solve this for you.
    2. has your car's radio connections been moved before? your radio may now be connected to a cable that it shares with other appliances. when the other appliances are turned on, natatalo ang radyo nyo. if so, an auto electrician can do something about it.
    blind shooter here.
    Di din ako electrician . First of, ano po ang radio ninyo? Is it China made? If not, ano po ang brand? I've tried different kinds of radios and I found the trusted brands (Pioneer, Sony, Kenwood, etc.) has the best sound as compared to china made brands. Maliban sa mas maganda ang tunog ng trusted brands, mas malinaw din ang tunog nila. Mas maganda ang filtration system kaya di dinig ang mga electrical at mechanical noises.
    Kung ok naman yung brand nyo, pwede nyong i-check kung ok pa ba yung grounding, both the engine and the cabin areas. Also, since yung electrical connections nyo is supposed to be dedicated or branched, meaning magkakaiba o magkahiwalay ng branch connections, mas mabuti na din na ma check kung merong mga pinagsama sa mga connections sa iisang branch circuit.
    Oct 2009
    add ka ng noise suppresor...
fm radio problem
