Results 1 to 5 of 5
    Jul 2014
    Ang bad trip. Suddenly last night drivers side door on my innova won't open.
    Pinag check ko na lahat:
    the lock/unlock is ok.
    the cable inside door panel is ok.
    the latch of door outside is ok.
    the main problem is the door locking mechanism.
    Big problem ko ngayon is paano tanggalin yung door locking mechanism kung hindi ko ma open yung door?
    need your big help of advice guys
    Quote Originally Posted by etgo View Post
    can you remove the door panel cover from the inside? if you can, then you should be able to access the mechanism from inside.
    Jul 2014
    yes sir, i can reach the mechanism inside. the problem was, the mechanism itself ang failure. was able to took a pic on the said mechanism, will post it later..
    Apr 2006
    Have you tried spraying WD40?
    That happened to me when i was diy reapplying the katol sealant on my door shells. Kelangan talaga ng katakot takot na elbow grease para ma release uli iyong mechanism. Sakit sa daliri [emoji28]
    to be or not to be, that always confuses me!
How to open the door in my Innova with defective mechanism?
