Results 1 to 6 of 6
- Nov 2009
- 8
November 16th, 2009 06:50 PM #1mga sir good day to you all bumayahe ako ng isabela sa norte!! of course meaning dumaan ako sa zigzag going there roads are really bad due to recent landslides that occured there, napansin ko lang nung nasa manila ako walang problem sa mga alarm lights lahat, pero after nung dumaan ako sa zigzag umiilaw ung engine oil light pinacheck ko ok naman daw marami pang langis
nung paluwas naman ako ng manila same problem parin pero once i got to manila nawala na sya need your expert advise mga sir
November 17th, 2009 12:54 AM #2
sa oil pressure po yata yan, baka mahina na oil pump.. pero mechanical yata oil pump so di ko alam kung paano ito hihina..
intay natin mga experts...
November 17th, 2009 12:37 PM #3
- Nov 2009
- 8
November 17th, 2009 07:04 PM #4
- Nov 2009
- 8
November 17th, 2009 07:08 PM #5
thanks partner sabi nga nung pinacheck ko ng mabilisan dahil nasa byahe ako baka nga raw ung connection ng sensor daw pero safe naman daw ibyahe rite now im here in manila na already so far hindi na sya nag re occur should this something i should worry about that will lead to a bigger damage???? your expert thought would be greatly appreciated!!!! thanks!!!!
November 17th, 2009 07:45 PM #6
You can't exactly monitor the engine oil if palaging naka ilaw or permanent na di na umiilaw.
Same as my lancer na ganoon din na laging naka ilaw.
I don't want to buy a new sensor(confirmed sira eto),
Kaya ginawa ko ay tinanggal ang lights
Of course ang hassle is, everyday check sa dipstick.
Xiaomi E-Car
