Results 1 to 16 of 16
    Sep 2009
    My 06 Hilux 4x4 d4-d(not flooded) - battery light indication in my gauge,so i took out my alternator(DIY) then brought it to a dependable mech. it was working daw. so what could be the cause for the bat sign to light?
    My 09 altis 1.6 a/t (flooded) -changed the main body ecu(junction block), EPS module and steering column. after all the new parts were installed, umiilaw parin abs, battery and the hand break light won't go off. iiyak nako!! and the radiator fan isn't working...took out the alternator as well, ok naman daw alt pero di parin kumakarga...help...
    my 07 altis 1.6 a/t (flooded) - changed engine ecu and integration relay.everything is ok except for the radiator fan not working and the headlights aren't responding - di umiilaw pati gauge. what could be wrong?
    I decided to seek help here in tsikot coz lumalaki na talga gastos, some mechanics have their ways to prolong what has to be done para tuloy tuloy bayad sa kanila..thanks in advance guys
    Quote Originally Posted by angelo_t View Post
    check the fuse box both in the engine compartment and under the steering wheel.
    check the fuse box both in the engine compartment and under the steering wheel. replace the radiator fan, malamang sunog na motor niyan, happened to our vios, cost us 8k sa casa.
    for the intrument lights and HL, check your fuse box under the steering wheeland the engine compartment. else the switches maybe the faulty ones. for the radiator fan, same as above.
    goodluck sir, sana makatulong ako.
    Sep 2009
    Quote Originally Posted by aejhayl17 View Post
    this is also called the clutch fan right?
    Thanks so much for the valuable information!=)
    aux fan ata sir? di ko matandaan part label niya. basta it cost us 8k sa q.ave casa. di nila nirecognized na under warranty kase basa yung motor, nilusong ng mom ko yung vios sa baha kase.
    Feb 2010
    Sa Araneta ave; Punta ka kay Boy Chincuaco Interiors; meron dun magaling na electrician na pwede mong kunan ng opinyon. Tell Boy that you are my friend. Willie
    Quote Originally Posted by still53 View Post
    si sir angelo_t po yung problemado hindi po ako. hehehe anyways thanks na din sa recommendations
    Sep 2009
    Thank you sir willie!susubukan ko po puntahan
    sa radiator fan, dahil binaha eto, most possible probs is dirty contacts especially sa carbon brush and commutator,,,or could be the connectors kung ok ang fuse.
    Sep 2009
    Quote Originally Posted by xda2jojo View Post
    so sir it's possible na hindi na po kailangan palitan yung motor? ill get it checked nalang po just to be sure. thanks for sharing po
    pacheck mo muna bos. di naman yan disposable type.
    Sep 2009
    updates lang po with my problems....
    ALTIS 09 - working na po yung alternator, maluwag lang pala yung screw for the alternator sa integration relay inside the engine fuse box. we tested the motor of the aux fan, gumagana sya, ok naman mga relay and fuses pero ayaw parin gumana pag pinaandar
    ALTIS 07 - ok naman po yung mga relays and motor ng aux fan pero ayaw parin tumakbo pag pinaandar
    I just bought a 2004 Vios 1.5G that might have been flooded. There is a "check engine" warning on the panel that doesn't go off even if the engine seems to working just fine, except for the noise when the fan goes on. I plan to bring it to the casa to be scanned but would like to seek the advise of those who might have experienced this. What could be the problem?
    Quote Originally Posted by Kieziritzky View Post
    definitely a faulty sensor in the engine (most of the time). forgot what sensor it is. the casa definitely knows it. take it there for diagnostics. cost about 3k including the parts and labor. it happened to my former escape 03 (not flooded) and my cousin's vios 05 (before being flooded)
    The 3k included the costs for both the diagnostics and the repair? And the problem did not recur afterwards?
    yup, in my case. the problem is all gone.
    Thanks man. That's surely reassuring. Hehe.
electrical problems....help pls
