Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    DIY : Innova Aircon Duct Cleaning / Dashboard Removal
    Dust and dirt accumulate inside the air ducts. Moisture from the a/c
    operation makes it an excellent medium for bacteria and fungus growth.
    Regular cleaning at least once a year will minimize growth of disease
    carrying organisms. But you can clean the air ducts , you need to remove the dashboard.
    To my fellow Innova owners, below is the step by step procedure in removing the dashboard of our beloved Innova.
    WARNING : This is procedure is very tedious and timeconsuming.It can cause some injuries if not done carefully.
    DO THIS AT YOUR OWN RISK.
    1. Remove the aircon switches on the center console. Remove screw on the middle switch. Pull-out the center console/panel. You need not remove the stereo and MID. Remove 2 screws holding the dash. Screws are encircled in the photos.
    2. Open the upper glove compartment. Remove the cover as shown. 2 screws that holds the dash need to be removed.
    3. This is a step bit tricky and challenging. Tilt the steering wheel
    downward. Remove the screw on the optitron meter cover panel. Slightly pull-out the panel. You cannot remove the panel completely but you should be ableto remove the 3 screws that hold the meter.There's another screw behind the meter. You need to tilt the meter inside to be able to remove that screw. You may need to remove the steering column plastic cover ( DO NOT REMOVE the steering wheel , Be careful not to engage the air bag as this might cause injuries ).
    4. Remove the side panels as shown.
    5. All the screws that hold the dash should have been removed by now. Dashboard now only being held by clips. Pull-up the dash starting from the center console then on both sides. You may now pull-out the dash.Pls. have someone assist you in bringing out the dash.
    6. The 2 center console vents needs to be removed. These 2 air vents are held only by clips.just pull it out carefully. Remove the clips on the vents as shown.
    There you go.Time to clean. I'll leave it to you the cleaning method. Vacuum cleaner will be needed as well as a lot of rags/towels. BTW , I permanently closed the air in-let/vent coming from outside. I do not use it anyway.This will also prevent dust from entering the cabin.
    Another big task is returning the dash back.
    Hope this procedure helps.
    Aug 2006
    Many thanks to you Ginnova, it would be a tremendous job but like you mentioned it is worth the effort.
    Just like to add that it would be safe to remove first the battery terminal before dismantling the dashboard.
    up ko lang ito para sa mga nagtatanong about dash removal
    Jul 2011
    Quote Originally Posted by Ginnova View Post
    removal
    salamat nga pala sir muntik ko ng makalimutan reply dito
    Jul 2011
    Sir ask ko lang kung may air filter ang innova E 2006 model? I removed the upper/lower glove compartment pero wala ako nakitang filter cover parang naka fix tas kinapa ko sa taas wala ako nakapang filter.. Thanks!
    Aug 2009
    Mine is 2011 model but I think pareho lang location ng filter for aircon. After removing lower compartment, may makikita kang rectangular na cover at the left side. Naka clip lang un. Look for the clip which locks the cover in place. Push the clip and pull the cover. You can see the filter inside.
    Aug 2009
    Ginnova, how can I access the air inlet, the easiest way? Kahit kasi na close yung vent , may pumapasok pa din na amoy from outside. I test it using an air freshner and spray it outside a little below the rightside wiper. Umamoy!. Kaya pala tuwing daraan kami sa tabi ng basura, may pumapasok na amoy.
    The easiest way to close the aircon outside vent is thru the plastic cover near the wiper. remove wiper arms then remove the plastic garnish covering it. sa may passenger side nandun yung vent. you can now cover it the way you want. this is easier than removing the dashboard.
    Aug 2009
    Thank you. A very big help!
    Jul 2011
    Quote Originally Posted by joey roo View Post
    Thanks for the reply sir pero mukhang wala talaga ang innova E 2006 model ....
    wala nga yatang cabin filter yung early models ng Innova pero pwede butasan para malagyan
    Jan 2009
    Note on sealing the air inlet.
    By design, the inlet allows a little bit of outside air into the cabin (even if set to recirculate) for health reasons. It basically allows air from the outside to displace the CO2 build up (which passengers exhale) in the cabin. The bad air typically exits from vents at the rear of the vehicle, usually hidden under the bumper on both rear fenders..
    In time, wear and tear on the recirculation flap seals may allow more air to come in than usual. However, going so far as sealing it airtight may not be the best for vehicles that normally carry multiple adults on long trips. The lack of oxygen may contribute to nausea and discomfort in the long haul. A work around is to "air" the cabin every now and then by cracking open the windows for a few seconds during the trip.
    pls note that there are other vents in the car. also the design of air vent and flaps makes it a dust catcher.
    Jan 2009
    ^ Curious as to where these vents are.
    You usually have a cabin filter to take care of most airborne dust.
    rear has vents covered with very thick material synthetic materials. older models do not have cabin filters.even with filters not all dust will be filtered so do not even attempt to let outside air in kung ayaw mo maligo sa alikabok lalo na kung matagal mong hindi binuksan ang air vent.
    Aug 2009
    Which is which kaya? But from my experience, iba talaga ang pasok ng amoy nya compare nung una. Baka may na ipit na foreign materials in between the flaps and the wall of the vent. Hazardous naman kasi kung may opening nang kaunti sa harap. Yung papasok na usok from emission ng sasakyan ahead of you will make you dizzy/sleepy while driving. Mas delikado yun.
    mayroon kasi yan parang foam na manipis sa perimeter ng flap na eventually nasisira. kaya siguro pumupasok na yung amoy sa loob. ganyan yung luma ko sasakyan dati, corollo big body. yung usok ng bus naamoy ko sa loob ng kotse so pinasara ko during air-con cleaning. so nung time na binaklas ko ang dashboard ko sa Innova I did not have second thoughts para i-seal it completely. you cannot also believe the amount of dust na nag-accumulate sa loob ng vent at flap. what you can do is put a thick material some sort of filter sa opening ng vent if you would not like to seal it.
    Jul 2011
    Sir Ginnova paano po tinatanggal yang mga yan? Thanks po..
    Remove the wiper arms first. yung nut is covered by a small plastic. then open the hood para tanggalin yung cover ng wiper assy.
    Jul 2011
    Wow! Ganun lang pala.. Thanks ulit sir ginnova!
