Results 1 to 3 of 3
- Jun 2013
- 2
June 21st, 2013 06:22 PM #1Hi guys. hingi lang sana ako ng tulong sa inyo... i have a 92 corolla smallbody. ang problem po eh pag mainit na yung makina, nakaaircon, matagal ng umaandar...at nagstop ka sa stop light or humps or nakafull stop ka.. eh biglang patay yung makina.. pero pag start mo ulit, one click lang start na agad ulit... nagpalit na ko ng fuel pump brand new, nagoverhaul na rin ng carb, pero ganun pa rin... suspect ko na lang eh ignitin coil and high tension wires or distributor.. please help po.. thanks guys
June 21st, 2013 07:37 PM #2
Check that it's not flooding... see if the spark plugs look wet. Also check your vacuum lines.
Overheating ignition coils can go out even during steady cruising... if it happens when you come to a stop or when you're stopped, it might be a vacuum or idle issue.
- Jun 2013
- 2
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
