Results 11 to 15 of 15
- Sep 2008
- 54
June 1st, 2010 09:10 PM #11nAlinis ko na rin ang cable.. what seems to be the problem. sana may expert mag post ng ideas nila. thanks
- Jul 2010
- 166
July 23rd, 2010 07:16 PM #12sir check nyo yung idle up ng aircon, bk dun ang problem. yung nangyari kasi sa akin nag adjust ako ng idle up 900rpm, ok naman rpm ko after ko adjust. then nung tumakbo na auto ko dun na nagloko biglang 1800 rpm ko pag naka aircon, inadjust ko uli pababa idle up ng aircon, magmula nun ok na sya. baka stock up sa idle up ng aircon yan sir
- Mar 2011
- 7
September 3rd, 2011 03:25 PM #13Tol,
Try to reset the ECU ( computer box ) by disconnecting the battery terminal by 1 min...:
- Jun 2006
- 1,139
September 4th, 2011 01:48 AM #14I had this problem before, even after cleaning the idle servo.
Resetting the CPU solved the problem.
- Sep 2011
- 1
September 14th, 2011 11:12 PM #15
high idle RPM at engine start
