Results 1 to 4 of 4
- Oct 2013
- 5
October 30th, 2013 10:09 PM #1bakit kaya ganun after ko magpapalit ng sa clutch lining
everytime na iaaccelerate ko yung takbo ko, parang may kumakaliskis na tunog? di kaya sa brake pads pinapaltan din nila yung brake pads. pero ganun padin.
October 31st, 2013 09:23 AM #2
Only while accelerating? Does it go away when you press your brakes or when you press your clutch? If it comes out while accelerating and turning and is a rough, grainy sound it could be your axles/CV joints need repacking.
- Oct 2013
- 5
November 1st, 2013 06:14 PM #3
nagstart lang siya magkaliskis na sound kapag segunda pataas. pag tinodo mo yung apak sa gas mo while accelerating parang nawawala na yung kaliskis. medyo nakakabother lang kasi di maganda pakingan yung sound. naobserve ko lang ito after ko magpapalit ng clutch lining.
ano yung axles/CV Joints bro?
November 2nd, 2013 01:34 PM #4
If it sounds like pebbles in a can, that could be detonation or " tope". If that is the case, try having the mechanic check and adjust your ignition timing and possibly, tune up your engine.
As for the axles, this is what drives your wheels from the engine. It has a bearing which needs repacking or replacement if it makes noise. You can google the part to read and learn more.
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
