Results 1 to 5 of 5
    Mar 2011
    Mga Masters ,
    Please help me , I replaced the clutch master ( Php 500 plus ) nung unang kabit , ok ang shifting pero later on..hindi smooth and shifting lalo na sa primera ( 1st gear )..
    Thanks po..
    May 2008
    bleed the system. replacement parts sometimes have clutch piston rubber seals that swell too much after a few days in brake fluid. it prevents the clutch from engaging even if it feels as if the pedal is fully depressed. could also be worn clutch plate and/or release bearing.
    Quote Originally Posted by goldrat View Post
    +1 dito. try mo i bleed muna yung clutch mo. kapag hindi pa din tumino, clutch disc na siguro problema. baka manipis na lining.
    Mar 2011
    Thanks mga Masters...
    if this is happening on all the gear then good point to bleed it but if its only happening on your first gear then the problem might be on your 1st gear synchronizer... might be a help for some.
Corolla 97 GLI -  Hard to Shift on First Gear..Need your help!!!!!
