Results 1 to 5 of 5
- Mar 2011
- 7
July 30th, 2011 03:19 PM #1Mga Masters ,
Please help me , I replaced the clutch master ( Php 500 plus ) nung unang kabit , ok ang shifting pero later on..hindi smooth and shifting lalo na sa primera ( 1st gear )..
Thanks po..
- May 2008
- 117
July 30th, 2011 09:56 PM #2bleed the system. replacement parts sometimes have clutch piston rubber seals that swell too much after a few days in brake fluid. it prevents the clutch from engaging even if it feels as if the pedal is fully depressed. could also be worn clutch plate and/or release bearing.
July 30th, 2011 11:19 PM #3
- Mar 2011
- 7
September 13th, 2011 03:22 AM #5
if this is happening on all the gear then good point to bleed it but if its only happening on your first gear then the problem might be on your 1st gear synchronizer... might be a help for some.
Hybrids and EV
